Thread: Vectra C battery replacement problem
    Dec 2011
    Kent
    confused Vectra C battery replacement problem
    Hi, hoping someone can help. I have had the battery off the car for about a week and now when trying to reconnect it the main fuse blew. Everything powers up even though it is all switched off. The ignition lights aren't working and the engine won't turn over. I've disconnected the horn to stop it blowing but I can't trace the fault. Here's hoping someone has an idea what is going on with it! Cheers.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Battery connected correct way?
    South east
    Are you connecting the + terminal first?
    Dec 2011
    Kent
    Thanks for your replies. That's yes and yes. I'm wondering if the battery has changed its polarity having been completely flat?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I know button battries can change polarity, but car ones??
    Its easy to check if you access to a multimeter.
    Dec 2011
    Kent
    Checked and have reverse polarity. Can I just drain it down and recharge again or would you suggest a new battery?
    Aug 2010
    south northamptonshire
    lucky mate the lorrys we work on if you reverse the polarity it blows the resister in the ecu meaning £4500 to replace + labour,
    to answer your question if its drained that low its prob worth just bite the bullet and get a new battery tbh
  1. Battery Replacement - Anything to look out for
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2017, 13:57
  2. Car Battery replacement
    By Casper85 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 20:35
  3. Vectra cdti battery/alternator problem help
    By goooba769 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 11:17
  4. key fob battery replacement
    By cranny 27 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:22
  5. Battery Replacement???
    By B19CBB in forum Engine & Drivetrain
    Last Post: 21st May 2008, 19:32
