Results 1 to 10 of 15
Thread: Secondhand DSLR questions
    Sodding Typical on Sea
    Default Secondhand DSLR questions
    OK, any of you good people who are keen photographers able to offer me some guidance on my hunt for a used DSLR?
    Many thanks for those that can help me
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Derek Mc View Post
    Don't worry too much about MP. Anything around 6 should do fine for starting out. The money you save on buying a 14.4MP put towards some decent lenses with low F-stops. F2.8 is a nice number. I have a Pentax sub £300 set up and am getting fantastic results as seen here. www.flickr.com/chriswilkinsonphotography
    The main use will be to photograph the shops I design and fit-out to get them with some decent quality rather than a pictbridge camera or worse yet my Blackberry I have a small Fuji Finepix 3.2 mp that is barely OK for the task but wanted some expert opinions.
    thanks very much Chris
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    So, you'll need some wide angle lenses. an 18-35mm zoom will enable you to get most of what you want in the shot. A 10mm will give you a wider still shot with a distorted/ fisheye look. It'll give you some quirky results. I'd also look at a tilt bounce flash and diffuser. It'll give you a better, warmer light on inside shots if you bounce the light off the ceiling. You'll avoid the 'glare' of a direct flash.
    I was thinking 1 28-55 0r 35>70 but mounted onto what though, my thoughts are a Nikon D40X or a D70 (cheaper) or Canon EOS 1000D (as in the past I owned a Canon EOS 600 35mm which so ahead of my photographic talent in 1990 that it was a bit like me using a Ferrari Enzo to go to Asda with
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I think you'll need something that goes lower than 28mm TBH . When i'm taking photo's around the house, i rarely go above 35mm. The 18mm gives you just that extra. It also makes places look bigger than they are
    Here's a priceless piece of advice a pro photographer friend of mine gave to me. Go to a shop and pick the cameras up. As soon as you've got your grip on it, you'll know which one you want. Technology wise, there'll be nothing in it.
    Thanks Chris,
    I think you have actually hit the nail. I think I already know what one I want out of those
    scottish region
    West coast photographer then Derek LOL
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Thanks Chris,
    That's why i ended up with a Pentax not a 'better' brand. The feel of it sold it to me.
    Quote Originally Posted by DAVIDD88 View Post
    LOL, it's for use in my business but nae doot I will find the odd occasion to snap a car or ten
  1. Best 1st DSLR????
    By ridgers84 in forum General Chat
    Last Post: 4th April 2012, 17:26
  2. DMF Issue on a secondhand 1.9
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2012, 14:45
  3. vectra secondhand parts
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2011, 13:35
  4. what dslr ?
    By pyro_maniac in forum The 'Off Topic' room
    Last Post: 7th November 2008, 19:11
