Thread: Engine steam clean
    Kent
    Default Engine steam clean
    I have a vehicle in a friends garage as it has a bad oil leak, he's had a look but as the underneath is covered in oil he can't see much, he has asked me to get the engine steam cleaned and take it back to him, he took it to one of those hand wash car washes in a petrol station and they wern't interested.
    Any ideas where I can get this done, the vehicle is in strood, Kent so I would like to get it done around there.
    South east
    Most garages can clean engines.
    A hand car wash (jet wash lance) uses cold water
    Sounds like they refused as someone has claimed against them previously
    Steam cleaning, uses exactly what it says; hot water
    Search locally for that specific term
    This should cost around £15, if it is cheaper than this make sure they are actually using hot (steam) water and not just a cold jet wash
    You could use a local jet wash, but there are some methods you need to use, to take into account the pressure and the cold temperature
    Throughout keep the engine running, do NOT switch it off
    Select the basic option (lance only)
    The first spray will include soap, hold this about two foot from the engine and apply in short bursts, allow the soap to flow through gravity
    Do NOT spray any soap on to the exhaust area or beyond the bulkhead (below the windscreen)
    The next spray is high pressure (cold) water
    Using the same technique as above, but pass the spray across the car (left to right, or right to left), at the end of each sweep allow the residual water to pass through the engine bay and evaporate with the heat
    Due to the danger of steam do not repeat the next sweep until the steam has ceased
    Finally, wash backward under the car, to remove residual dirt from the frame, you can place the lance about 6" from the chassis, but again avoid the exhaust components
    When you have finished drive the car for at least 20 minutes and recheck the engine bay for any residual water, only then switch off
    Kent
    Thanks, from what I understand he needs it cleaned from underneath, I've googled it to death maybe I need to get a list of car washes and ring them in the morning.
    Barrow In Furness, Cumbria
    It could be more of a valeting company than just a car wash that you need.
  1. Engine bay steam cleaning
    By ridgers84 in forum General Motoring Chat
    Last Post: 29th January 2012, 10:43
  2. Wot to clean on a 2.0t engine
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 19:29
  3. best way to clean an engine bay?
    By tom_p_2000 in forum Detailing and Car Care Discussion
    Last Post: 31st May 2009, 22:05
  4. engine steam clean??
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 13:03
