Results 1 to 10 of 22
Thread: Which Towbar????
    Apr 2012
    Swindon
    Default Which Towbar????
    Hi, I'm looking for a towbar (12N only) for my Veccy C H/B
    I want a detachable one as I don't tow often & don't want to spoil my arse end too much
    I have a budget of £200 & will be fitting it myself. Any recommendations?
    The ones I'm considering ATM are:
    BOSAL ( http://www.towequipe.co.uk/products/...loon-02on.html )
    WESTAFALIA ( http://www.towequipe.co.uk/products/...-02-on-kt.html )
    Both are £197 inc std 12N wiring kit. I assume I'll also need a 7-way bypass relay.
    Cheers, Nez
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Apr 2012
    Swindon
    Thanks, It's a bit too far to collect, but I've asked for price on postage
    Cheers, Nez
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    I would thoroughly recommend the Westfalia. Its a quality towbar and really easy to attach and detach. When its not fitted you wouldn't know and best of all its really easy to DIY fit and a good opportunity to fit reverse parking sensors at the same time.
    Apr 2012
    Swindon
    Cheers, the Westfalia does look good, I'll probably go with that
    Cheers, Nez
    Sent from my GT-I9100 using Tapatalk 2
    Apr 2012
    Swindon
    Right, that's the Westfalia & Parking Sensors ordered.......guess what I'll be doing this Bank Holiday!
    Aug 2010
    Leeds
    Does it need the dedicated wiring harness like the Astra does a plug in module or is the vectra different?
    Plenty of used ones on e bay around £50.00 and cheaper, i know you want detachable you may find one and save some cash.
    Regular Member Cyruskint's Avatar
    Jun 2009
    Dorset
    Westfalia - great towbar
    I have had 3 different brands on Vectras/Siggys, but the Westfalia has been best (and most corrosion resistant) Opel seem to fit them when ordered new I think.
    Plug-in module certainly needed for full Canbus cars (2005 MY onwards?) but easy to fit once side panels detached.
    Jun 2009
    Dorset
    Not much into bypasses - the Vaux kit with module may be a bit pricier, but it at least works with the electrics (rather than bypassing...)
    Quote Originally Posted by Cyruskint View Post
    ijk571
    Guest
    Don't you have to drill 4 holes in the boot floor and then sandwich two plates with bolts between the floor; the lower one having the frame fitted to it? Sure I read that somewhere. I looked at one to put a bike rack on recently.
  1. towbar
    Last Post: 17th March 2011, 10:49
  2. Which Towbar?
    By humphshumphs in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 21:39
  3. towbar will it fit?
    By xyy81t in forum The 'Off Topic' room
    Last Post: 25th March 2009, 18:50
  4. Towbar help please
    By Robclowes in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 16:56
  5. towbar help
    Last Post: 12th April 2008, 23:11
