Thread: Are these any good???
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    84 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    Default Are these any good???
    http://www.ebay.co.uk/itm/KIT-TRACK-...item1c26258e2b
    comments appreciated please
    rab.............
    South east
    Are yours knackered?
    Jan 2008
    North Lanarkshire
    84 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    Quote Originally Posted by Rebellion View Post
    am not really sure............just wann get rid of the knocking and the only way, is by replacing all the parts.
    just ordered the saab heavy duty drop links.
    so im looking at track rod ends, wishbones and arbs next
    problem is...........i cant seem to find strut top mounts for the sri...............would the strut top mounts from the standard vec set up fit the sri?
    South east
    Lots of Vecs have knocking in the suspension that people manage to sort out, but it's very rare for anyone to replace those arms, so they're probably not the cause. You need to be methodical, otherwise you could spend a lot of money and still have the noise. Track rod ends, for example, do wear out and they can affect the handling, but don't usually cause any noise.
    Is the noise from the front? Does it happen at random times when just driving along a straight road? Or when going over bumps? Or when turning the steering at slow speeds? Each of these symptoms has a different cause.
    Jan 2008
    North Lanarkshire
    84 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    its only over the bumps......like a metallic knocking at the front end.
    ive replace the struts with sachs supertourings all round, eibach springs, ordered the heavy duty drop links and i have the SNR strut top bearings.
    i was replacing everything to see if the noise would go..............but if your saying the wishbones dont usually go, then what else cud it be?
    the ball joint? bushes on wishbone? track rod ends? arbs?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I would try the ARB's my back end was knocking every time i hit a pothole or hump and that's what it was
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    What about the radiator mounts, if it's when you go over bumps?
    Jan 2008
    North Lanarkshire
    84 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    Quote Originally Posted by Mark-R View Post
    problem is.............ive checked out which arbs are on the front of mine - 24.2mm and smooth, no raised bits - but checked with seller on ebay and they came back to me and told me that mines are the 24.2mm but have raised bits on the arbs.
    Jan 2008
    North Lanarkshire
    84 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    Quote Originally Posted by Gubmint Agent View Post
    if these are gone.............would the knocking be as loud as what im hearing???
    its loud as if its suspension related
    South east
    Don't pay any attention to whether your ARB bushes have raised bits or not - as long as you are certain what size your ARB is, either from accurately measuring it or by looking at the part number on the side of the existing bush, then buy some bushes of that size, regardless of the raised bits.
  1. Maybe Good Things Do Happen To Good People....
    By Leemarksmith in forum General Chat
    Last Post: 16th October 2010, 22:12
  2. Cheap rear spoiler...too good to be any good?!
    By Lightboy in forum Styling
    Last Post: 26th February 2010, 23:03
  3. seems a good set up for a good price?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 09:31
  4. Some good news, and some not so good...
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 19th August 2008, 10:06
  5. Good spec Signum, Good price too!
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2007, 18:44
