Thread: Windscreen washer
    Regular Member hadiislam's Avatar
    Apr 2011
    Newcastle upon Tyne
    Default Windscreen washer
    Hi guys,
    Fitted a windscreen washer bottle sensor recently which works fine. The bottle was leaking a little bit so decided to refit sensor with correct gromit. This is now fine and no leaks. The problem I now have is no water is coming out either washers front or back. I can hear the motor going so it's definitely not at fault, and have double checked everything to see if everything has her. Put back together properly and it has. Can anyone take a guess as to what my fault may be?
    Thanks.
    Is the filter at the bottom of the bottle (that the motor pushes into) blocked?
    See the HOW2
    Apr 2011
    Newcastle upon Tyne
    It's not something I have checked yet, you reckon it would be possible to do while at work with no tools? Had a look at the how2 and all it really mentions is the torx for the mud flap?
    Yes, all you need is a T20 torx bit and something to tie back the arch liner out the way to gain access. However, unless you've got some running water, you won't be able to rinse out the bottle or filter.
  1. windscreen washer help
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2013, 08:56
  2. Windscreen washer
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 12:46
  3. Windscreen Washer Jets
    By John Bishop in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2010, 12:46
  4. Windscreen washer problem
    By heheshamon in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 14:54
  5. Windscreen Washer Motor
    By cae2020 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:31
