Thread: half canbus vectra 2003 new stereo help
    Aug 2009
    AMMAN
    Default half canbus vectra 2003 new stereo help
    hi all please I need help in my problem and I think that vectra c in England have more adapters and acceories you can help me
    I have bought a Chinese DVD gps stereo which is designed for Opel vectra ( my original stereo is ccrt2008)
    http://www.sundaybuy.com/Car-DVD-Pla...-8919_749.html#
    after I have received the stereo I found that the canbus cable is different from mine (it is for full canbus models) and they don't have for 2002-2004 cable
    so now I'm in trouble iv searched on internet for adapters and i.ve found this
    http://www.halfords.com/webapp/wcs/s...Id_265880#tab3
    from halford
    and this
    http://caraudiosecurity.com/shop/pro...s_id/7101.html
    but the idea till now is not clear if I use this adapters will it make me able to enter bc and remove alarms which appear on the screen
    or anybody have any idea for a compatible adapter for my car
    please help I don't want to damage my car electrics
    from halford
    and this
    Regular Member coldo's Avatar
    Scotland
    Bit of double posting there lol...
    The issue you will have is the car connections you have are ISO (used on half can bus) and the head units connectors are quadlock fraquar for full can bus (think thats the spelling) meaning you need to buy or make a patch lead to connect the two....
    the two leads you have listed are for ISO to ISO with a stearing wheel patch lead and wont work unless you start cutting witing on the radio's loom which im not sure will even work...
    Something like this, http://www.ebay.co.uk/itm/Vauxhall-I...item3f1348897f is what you need...
    You will then need to muck about with the steering wheel whiring to get it to work (I Think)... I have emailed the seller to ask this questions...
    Aug 2009
    AMMAN
    thank you coldo
    yes it is good for direct connection
    but my question is will this
    1-make my car use steering wheel control
    2 enable entrance to bc menu
    Scotland
    1. Not sure. I think you may have to cut into the wiring loom to make the stearing wheel controls work (think that's what the spare wire is for on the ebay loom)... Best to ask the supplier that question...
    2. If your car is half can bus then you will have three buttons on your stearing wheel. To access the BC menu you will have to use the wiper stalk with the BC function on it (http://www.ebay.co.uk/itm/VECTRA-C-W...item231d3bbf31) and if you dont have it activated you will need to get this done using Tech2 or "other" software. The BC functions only work with a gid or higher display. Do you have this display at present which shows range, fuel, miles etc along with radio station and time / temp or a two line display which shows the radio station, temp and time (two line display)?
    If you have the two button and scroll wheel control on the stearing wheel then you are full can bus which changes things completly for wiring etc of your car... meaning the radio you have bought should be plug and play!
    Aug 2009
    AMMAN
    yes my display is gid which shows consumption and others info
    my car is 2003 half canbus (ccrt2008 stereo) and stearing wheel controls is three buttons in each side
    for adding wiper stalk it wil get more complicated i prefer to to use the adapter even i will need to cut or switch simple wires (like power and speakers)
    Scotland
    How do you control the GID screens and functions right now (is it through the CCRT2008 radio)..?
    If so then I think the only way you can keep using it will be fitting the stalk... It's dead easy to do and you only need to activate one bit on the car to get it fully working... I managed it with the "other" software which most people have on here..
    As far as I know there is no way to get the GID to work using the stearing wheel contolrs on the Half Can setup and no way the radio will be able to control this either... Although I may be wrong about this... Need to cofirm that with the manufacturer...
    Aug 2009
    AMMAN
    thank you i will see if there is wiper stalkes available in our country to make a test
    Jun 2012
    Barnsley
    Hi, i'm goin to try and fit cd30 in place of cdr2005. How would i go about activating things like you said. I'm new to forums so plz be gentle.
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. Half can iso car but stereo has quadlock with canbus decoder.
    By Ace1981 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2012, 11:02
  3. can a facelift satnav stereo and screen be fitted to a preface half canbus car?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2012, 00:19
  4. 2005 vectra 2.2 sri, preface or facelift half-can or full canbus?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2012, 13:41
  5. Retro fit Auto lights (Half Canbus 2003 GSI)
    By chickenwing in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2012, 17:38
vectra c half canbus
Does a good 2004 vectra have canbus
vauxhall vectra half canbus stereo
купить can bus decoder опель вектра с
vectra c activating wheel scroller www.vectra-c.com
half can vectra stereo adapter
ahld vectra c
canbus system on vectra c
vectra c aftermarket stereo steering wheel controls GB half canbus
can bus decoder opel vectra c
