Thread: Can you guess the fault?
    Regular Member simon7257's Avatar
    reading
    Default Can you guess the fault?
    Ok so I thought I'd share the info and have some fun alone the way
    A pat on the back if you guess what's the fault
    It's a 1.8 petrol z18xe engine
    The symptoms are rough idling and hesitation while cruising at motorway speeds
    The fault codes are
    P0110 - intake air temp sensor 1 circuit
    P0130 - O2 sensor circuit (bank 1 sensor 1)
    P0220 - throttle position sensor/switch b circuit
    P0340 - camshaft position sensor a circuit*
    P1550 - Electronic throttle system (ETS) - in emergency mode
    Enjoy
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Similar symptoms to you except not on motorways. I have the P0340 - camshaft position sensor a circuit error.
    I have a new Camshaft sensor but you need to remove the timing belt and vernier wheel to get to the sensor (Nice design Vx!)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    MAF sensor
    Dec 2011
    Seaham
    Blown Fuse?
    reading
    Not maf sensor nor a blown fuse but keep the guesses coming in
    It's an interesting fault that goes to show how important it is always go back to basics while diagnosing your car
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Earth problem on ECU
    Dec 2011
    Seaham
    One of the electrical plugs had come undone?
    Regular Member GoldenWonder's Avatar
    Durham
    As above -loose connector or damaged wiring on connector?
    reading
    Very close but good enough, it's actually the multiplug which goes onto the ecu has a poor connection where the terminals have opened up inside the plug this loom runs from the ecu over the top of the engine connecting all the sensors and the injectors.
    Just goes to show it's not always a good idea to throw money at your car replacing everything that shows up when code reading (like the previous owner, HA!) hence the back to basics advise and a good old wiggle test while watching live readings, I hope this helps and most of all saves everyone some money
    Feb 2012
    Sale
    Default Fault code U2103 on tyre pressure system
    I have the fault code U2103 on the tyre pressure monitoring system fitted to my 2002 vectra 3.2, any ideas as what has caused this or how to fix it.
    Any help would be great.
    Pete.
    Quote Originally Posted by simon7257 View Post
    The fault codes are
    Enjoy
  1. Guess what!!!
    By BigWilko in forum Styling
    Last Post: 10th September 2012, 15:13
  2. Guess the fault
    By Critch in forum Y & Z30DT Specific
    Last Post: 7th August 2012, 01:14
  3. Replies: 15
    Last Post: 9th July 2011, 22:19
  4. 2.2 direct - guess the fault!
    By Jaffatubes in forum Engine & Drivetrain
    Last Post: 13th January 2010, 23:47
  5. Guess the (my new) car! :)
    By AntSSSS in forum The 'Off Topic' room
    Last Post: 26th May 2009, 00:42
vectra c ecu multiplug poor connection
camshaft position sensor bank 1 location z18xe
