Results 1 to 10 of 24
Thread: 1.9 CDTi Swirl Valve Issue
    May 2012
    Dundee
    Default 1.9 CDTi Swirl Valve Issue
    Hi all,
    New to the site, apologies for first post being a problem!
    Picked up a 54 plate 1.9 CDTi 150 Vectra over the weekend. Had the engine cover off today and noticed a possible issue with the swirl valve actuator rod.
    It's connected to all of the valves, but there seems to be a lot of play in it. ie you can hook a bit of wire under it and pull the top of the black valves up towards you a couple of mm (which is what the Pierburg bulletin warns of) and you can pivot the bar backwards (towards back of engine bay) but it flops back as soon as you let go. There is also a bit of oil sitting on top of each valve.
    The car isn't smoking there is no light and it drives fine but today it lost power twice quite markedly pulling away from a roundabout and wouldn't rev until I dipped the clutch and very slowly the revs picked up to about 3k and then were fine again. This could quite easily be something else of course, but would that be indicative of a sticking/failing valve?
    Does this sound like impending inlet manifold replacement? or am I looking for faults
    Thanks for any info
    May 2012
    Dundee
    Forum back up - bit more digging reveals something very similar here
    Sounds like could be a matter of time and with the amount of miles I'm doing - will probably be sooner rather than later
    With regard to the problem I had today, is it likely that is something different? Would the swirl valve fault just clear after a few seconds of poor running and be fine for the rest of the journey? Judging by the state of the boost sensor, there's not been a regular de-coking regime going on!
    What are the best steps to safeguard against failure? I'm assuming give the EGR/inlet manifold a good clean out to make sure the swirls aren't having to work against all the crud, is it worth blanking the EGR and putting up with the EML?
    I'm thinking perhaps the warranty I'm just taking out is a good step.
    May 2006
    scotland
    Ok, start with the easy things first and most probable. First thing I would suggest is the EGR valve. If you have access to a code clearer then you can disconnect the EGR valve electrical connection and drive it around for a couple of weeks (you will need to clear the code when you eventually re-connect it or drive around a couple of weeks until the spanner before startup dissappears). There is a very high percentage probability that if it is the EGR valve causing the problem, then the car will drive fine without further issue while it is disconnected (you will also get the eml light on the dash but this will go out when you re-connect EGR). If this is so, then it is the EGR is your problem. You can either clean it or buy a new one (£100 approx). Next I would take out and clean the MAP sensor (easily done, costs nothing but carb cleaner).
    Now to the swirl valves. Yes, they can cause limp mode if they are sticking. However, I would look at the above firstly. When my swirl valve rod fell off, I glued valves 1,2 and 4 copiously. There are plenty of posts on this forum about gluing them open, do a search.
    May 2012
    Dundee
    Thanks mate, I was thinking along the right lines then I think. Whipped out the MAP sensor and cleaned it. No re appearance of the limp mode (I assume that's what I had when the car wouldn't rev?) but only a 15 min journey each way this morning.
    EGR is next, hadn't thought about disconnecting it and driving it for a bit - top idea thanks. Beyond that I fancy giving it all a proper clean so the valves aren't being worsened.
    Also hadn't realised you could glue the valves open. I'm guessing that will also put up a fault code or does it just = smokey running. I'll have a search for it.
    Thanks again
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Also check that injector plug number 3 is blue and not yellow, if its yellow it needs replacing with an upgraded blue plug and wire sooner rather than later.
    May 2012
    Dundee
    Ta very much - I'll check it right now
    May 2012
    Dundee
    She be Yellow.......
    Meant to say got a op-com on the way, I reckon it might get some use
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Ninj View Post
    i am sure you meant a software diagnostic tool..........................
    May 2012
    Dundee
    Yep, got it thanks.
  1. Quick help please - cdti swirl/light/water damage issue
    By sandbagsniper in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2012, 21:02
  2. CDTI Swirl Valve
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2011, 18:12
  3. are 2007 CDTI SRI 150s prone to Swirl Pot issue
    By circushead in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2010, 18:24
  4. 1.9 CDTi 120. EGR, Swirl Valve or ???
    By mjsignum in forum Engine & Drivetrain
    Last Post: 13th April 2010, 15:23
  5. 1.9 CDTi Swirl valve
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 16:14
