Thread: Diesel housing looks like it could have a small leak :-(
    Redcar
    Default Diesel housing looks like it could have a small leak :-(
    Cleeaned my EGR and Boost Sensor today and noticed that diesel filter housing looked greasy. I felt underneath and its wet but cant see a drip or ovious leak point.
    Engine : 1.9 CDTi
    It might just be the seal as I have known 'O' rings to leak.
    Redcar
    Would a leak reflect on mpg computer? I cant see it been to much as cant see a leak just wet residue. But with current prices every drop counts :-D
    Engine : 1.9 CDTi
    You wouldn't notice it effecting the mpg.
    Nov 2010
    East Midlands
    Trim : design
    Presume you still have the 1.9 cdti (150) as shown on your profile - helps if you tell us what model/year. Where is the leak on the bottom of the filter housing or the top - if the bottom have you checked the small drain screw is secure and sealed and also the fuel pipe connections?
    Redcar
    Its a 55 plate sri mate. Iam not sure it just looks moist and underneath the housing the bits and pieces are moist.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Oil filter housing leak.
    By Nez in forum Engine & Drivetrain
    Last Post: 12th December 2012, 16:31
  3. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  4. Fuel filter housing leak any suggestions?
    By Toe-side in forum Engine & Drivetrain
    Last Post: 11th March 2012, 12:00
  5. Fuel leak from filter housing
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2010, 23:27
