Thread: Lifespan of a 1.8VVT
    May 2012
    Leeds
    Default Lifespan of a 1.8VVT
    Hi,
    What do you think the lifespan is of a (well maintained) Vectra 1.8VVT engine is? Mine has done 70K and, before I spend toooo much money on the car, I would be interested to know what the typical mileage on that engine is before its death. If it's likely to conk out at 100K then I might be better buying a lower mileage car.
    Cheer
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    17 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    i would say aslong as its looked after and serviced regulary and not ragged and abused theres nothing stopping it doing another 70k
    Regular Member GoldenWonder's Avatar
    Durham
    Not the same engines I know, but I put 175k on my Carlton 1.8, and 155k on my Cavalier 1.6, and 101k on my Manta!
    And they're all much older designs - so as said above, look after it and a pinch of luck and it can go for a lot longer!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    100k? I dont know of any engine that cant make 150k easy these days. Regular oil and filter changes(avoiding VX service recommendations) is the best way to extend the life of any engine imo. Of course not bouncing it off the rev limiter every gear will help a bit too.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    As above i change my oil every 6 months regardless of mileage
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Quote Originally Posted by wolfie78uk View Post
    Hi,
    Cheer
    this is the non vvt 1.8 have a read
    http://www.vectra-c.com/forum/showth...22#post1666822
    the only difference is yours has the variable valve timing version and ive seen them on autotrader for sale with 140 thousand miles on them
    My first Vectra B went to 140K miles (in 6 years) and it is still showing on databases with current MoT and RFL
    I would expect at least 100K miles out of any modern car (and as the years go by this to increase to 150K miles before long)
    If you require your car to/from work, then look at a third party warranty once the OE warranty expires at 80K miles
    You will note most third party warranties will not cover in excess of 100K miles
    hull
    160k on a guys 07 reg at my work (taxi), still sounds sweet.
    Aug 2010
    Leeds
    There should be no reason why your engine can't do 300.000mls without major work been done if you service it regular, the key is the oil and filter changes and using good quality oil.
    We had gas fork lifts from new serviced by us they did equivilent of 350k before the heads came off for work all we did was change the filters regular and these engines run very hot.
    Most cars die around 150k or 10 years old due to neglect or extended servicing which gets to 18 months or 2 years the oil is sludge the engine packs in.
    So if that was mine id use nothing cheaper than vauxhalls own brand oil and genuine filters, the oil i like is Millers oils but the price is a bit higher, you may need to use a little thicker oils as it gets on a bit like semi synthetic 15/40 when it's doing 150k.
  1. lifespan of an autobox
    By david106 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2012, 14:04
  2. 1.8vvt
    By platts007 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:24
  3. 1.8vvt
    By starykokot in forum Petrol Engine related
    Last Post: 2nd May 2011, 20:26
  4. Pads and Discs Lifespan
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 22:20
  5. 2003 2.2 SRI Timing Chain Lifespan?
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 13:25
vectra 1.8vvt bouncy
