Thread: Issues with steering along with ABS and TC lights
    Feb 2012
    Worcs
    Default Issues with steering along with ABS and TC lights
    Hi guys I have a 3.2 Vectra GSI on a 53 plate. The TC and ABS light used to come on every now and again but more recently seem to be on all the time. The steering can also feel notchy at low speed and when trying to perform 3 point turns or parking the steering becomes very heavy. While the lights are on obviously the TC is not working but steering still feels power assisted.
    Any ideas?
    Regular Member Dan.'s Avatar
    milton keynes
    same thing happened to my gsi, came up as a faulty steering angle sensor, turned out i need a new cim unit
    May 2006
    scotland
    I would try disconnecting/conneting all related electrical connectors. Make sure they are clean and firmly attached/fully home. I had an intermittent ABS/TC combined warning light very occasionaly over the past 6 months then suddenly got a whole lot worse. It turned out to be the cable under the fns wheelarch that had started to break internal inuslation and was making an electrical path to voltage. Swapped cable for a new one and problem solved. Your problem may or may not be a single one.
    Nov 2010
    East Midlands
    Trim : design
    Hi Mate, Any faults showing. Worth considering your steering pump - have you checked your p/steering fluid level? Also get you alternator/battery checked to make sure both are in tip top condition - failing alternator can throw up some strange symptoms including p/steering issues.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    My tc and abs lights initialy came on intermitently over the last 3 months,recently they stayed on all the time. Despite taking the loom apart and cleaning it twice I ended up replacing the loom(£14.00) from vauxhall ...no more problems.
    May 2006
    scotland
    Yep, exactly the same. The auto electrician who did mine stated that the cable had actually began to breakdown internally and was shorting out.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Had the same, also needed a new cim.
  1. Power Steering Issues, Solved
    By jatint in forum Engine & Drivetrain
    Last Post: 10th August 2013, 17:38
  2. Power Steering Issues - 3.0 v6 cdti
    By larann in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 23:08
  3. Brake/Steering Issues
    By andyvectradon in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2011, 13:59
  4. power steering issues part 2
    By robertgsi in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2011, 11:49
  5. Anyone had issues with warning lights after LED conversion?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2010, 23:47
