Results 1 to 10 of 19
Thread: Car starting on ez-start then on its own and white smoke.
    Apr 2012
    Plymouth
    Default Car starting on ez-start then on its own and white smoke.
    Bit of history first,
    My car has just had new timing chains fitted (2.2DTi) and timed up correctly with timing tools. Leak off pipes were changed. Headgasket was changed whilst doing the chains also. Fuel system was primed prior to starting but nothing was happening.
    This morning i found a couple of wires that had been bodged together that come out the back of the fuel pump. Sorted that out and found the car now does run but only with ez-start to get it going and its a little lumpy with white smoke. As soon as you let off the pedal to bring it to idle, it just dies.
    Any ideas people?
    Really dont want to sell the car but im at my wits end with it already and i have only had it a month.
    Thanks in advance.
    Aug 2010
    south northamptonshire
    not sure wether this is true but i heard before that using easystart in dti's can make the piston kiss the valves might be worth checking if true or not before you keep using easy start plus engine gets addicted to the stuff brake cleaner in a squirty bottle is better
    Nottinghamshire
    You mean the wires that run from the ECU on top of the pump into the pump itself?
    I would have thought that these would only need to cut if the ECU had been separated from the pump - and that opens up a whole .
    Apr 2012
    Plymouth
    I have stopped using ez-start now. I re-checked the timing and its definatly spot on.
    There are 4 wires that run at the back of the pump into a connector that sits between the outlets. these have at some point in there life been cut and reconnected (there solder joints, all be it not very good soldering!) I can see where your coming from, but my argument is, it was working fine before before i changed the timing chains. Hopefully it is just the fueling system being a right mare to bleed.
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    Quote Originally Posted by bridge_eee View Post
    cant see spray stuff altering the timing me self .
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you getting fuel to injectors?
    Compression test maybe needed.
    Apr 2012
    Plymouth
    yes, fuel is getting to the injectors.
    Its got brand new leak off pipes also which are clear so i can see whats happening. Although i am not sure what i should be seeing.
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Have you got a compression tester?
    Apr 2012
    Plymouth
    I dont have a compression tester. I think i know someone that has one but will take me a while to get hold of.
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If theirs fuel getting their you need to confirm cylinder compressions are ok,
    Where the valves touched while head was off?
  1. Replies: 53
    Last Post: 16th November 2012, 22:42
  2. Poor Starting & Thick White Smoke (2.0DTI)
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 4th June 2012, 13:47
  3. White Smoke on Starting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 12:47
  4. white smoke on start up
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 5th April 2010, 23:31
  5. White/Blue smoke on start up
    By jsr645 in forum Engine & Drivetrain
    Last Post: 15th May 2009, 22:26
