M replacing a cd30 with a screen so he has trip comp and I've plugged everything in and nothing working anyone help
when you say nothing working, do you mean that absolutely nothing is working on the cd30 /screen at all?
Put his back in with 2 line display and radio working and screen but nothing on the head unit working no lights no buttons work put the other unit and gid screen in and nothing working
Correct mate put his original one in all works but nothing on cd30 ie lights or buttons but can control on steering wheelOriginally Posted by Caveman_nige
was the cd30 definately working correctly in the donor car?
Not sure was on eBay and I believe it was a member on here
It sure was working 100% when I sold it, it was also packaged up extremely well (wrapped in loads of bubble wrap etc) to make sure it wasn't damaged in transit.
Marc I tried sending you a PM but your pm's are full.
I'm not to sure why its not working, I would expect the something to power on at least? Its going into a full can car? I think the wiring may need fiddling if its not?
When I swapped it for a cdc40 Dab it plugged straight in and worked straight away. Has a fuse blown? Is the connector block on the back of the unit locked into place properly?
On another note, did your mate find the code on top of the unit ok? Just, I never heard back from him when he said he didn't have it.
Hi mate his car is a facelift 55 plate I decied to try again as we are on our way Scotland so took his out put the the cd30 u sent and it worked so connected the screen and it worked straight away very odd no need for the code to be put it so he is happy now thanks bud
Glad to hear its working Marc, yeah I knew the code wouldn't be needed but including it allows the buyer to divorce the unit and screen etc should he ever want to.
Very strange though! When I fitted the CDC40 the cd stack wouldn't load cd's for some reason, then tried it the next and and it was fine and has been since lol, gremlins I say!
