Results 1 to 10 of 13
Thread: New GM discs and pads are grabbing....
    Regular Member chickenwing's Avatar
    Feb 2012
    Default New GM discs and pads are grabbing....
    I have a '03 GSI and I have fitted new GM discs and pads all round.
    I now have an issue where my front to wheels feel like the brakes are on constantly. I jacked the car up and tried to spin the front wheels, but the are very stiff. I can turn them but I have to put a bit of effort in to it and they don't spin freely.
    The rear ones seem ok and will spin freely, but still not as free as I think they were before.
    I know pads will make a bit of contact with discs, but this is like the pedal is being pressed a bit constantly.
    I then took the pads back out, copper greased the the sliders, cleaned them up again and put them back, but still the same.
    I don't really want to have to strip the calipers and bleed the system, but not sure what to do next.
    It sounds like a pressure thing or all four calipers are sticking hmmmm.
    Apart from taking the cap off the brake fluid reservoir, I haven't messed with the brake fluid.
    Any suggestions?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Who fitted them ..? Fully trained mechanic ? ... If they wernt like it before and they are now it is either the wrong parts or the fitting is wrong or something had been damaged / broken during the fitting ....you need to take it back to who ever fitted them or find some one who knows what there doing .. Brakes are important
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Do the slides move freely in the followers? Corrosion can build up under the rubber followers preventing the slides from moving freely, especially on the rear.
    East Ayrshire
    Trim : SRI XP1
    Have you made sure the pistons are pushed back enough? Sometimes they just need a final wee push. If they aren't right back then that'd explain why the pads and discs are rubbing. They also take a couple of hundred miles to bed in properly after that
    Glasgow
    Are both front wheels doing this or just one???
    My bet is its time for some new calipers going by the age of the car and my previous experience with my old 53 reg GSi.
    Feb 2012
    Quote Originally Posted by benny View Post
    I fitted them. I have fitted pads and discs before, never with any issues. Pads and discs are the correct ones. cheers
    Feb 2012
    Quote Originally Posted by stevie16v View Post
    I pushed them back completely, so there was more than enough room to fit the new pads and discs.
    Feb 2012
    Quote Originally Posted by byebyeitsagsi View Post
    Both front wheels are doing it and to a lesser degree, the back ones. I'm starting to think it's something to do with the brake fluid. As I get in the car from cold, they seem ok. As soon as the car warms up a bit, the brakes feel like they are gripping a bit. I wonder if there is a bit too much fluid in there......hmmm
    Feb 2012
    [QUOTE=benny;1811336]Who fitted them ..? Fully trained mechanic ? ... If they wernt like it before and they are now it is either the wrong parts or the fitting is wrong or something had been damaged / broken during the fitting ....you need to take it back to who ever fitted them or find some one who knows what there doing .. Brakes are important[/QUOTE ]
    Yes, all the sliders move freely. I have taken them all out and re-greased them.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    You need to get someone to press the brake pedal while you watch the pad, you should see them move slightly to grip the pad and then when the pedal is let up the pads should move away from the disc, these movements will be very small so look closely! Other than that it sounds like either the pistons or sliders are sticking...
  1. New pads and discs
    By mikey2704 in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2012, 21:41
  2. Discs and pads
    Last Post: 18th May 2012, 01:37
  3. Need new discs and pads
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 21:46
  4. Discs and pads
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2010, 20:46
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
