Thread: Half screen to full screen,
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Half screen to full screen,
    Bought new full size screen (not say nav) to replace half screen with two buttons on it. Any one confirm it'll be a straight swap? Will I need anything to make it work fully?
    2006 exclusiv estate 1.9cdti 150.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Has it been divorced from the head unit from the donor car? If not you'll need it sorted out by Tech2 mate.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I got proper full verison op-con, how do I get about to do that? As I bought screen from eBay.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Usually, wiring wise - it should be plug and play to fit a Full CAN BID / GID or CID in place of a TID
    BID = Board Info Display
    CID = Colour Info Display
    GID = Graphical Info Display
    TID = Triple Info Display (with clock buttons on bezel)
    Some people have found that they do not have wires in pins 2 and 3 of the Display connector.
    If not, then you need to do as follows: -
    Pin 1= brown - link this to pin 2 (ground wire)
    Pin 5= red - link this to pin 3 ( CAN controlled Live - fused supply on 5)
    Regarding Opcom / Vauxcom - The official comment is that you should speak to Ilexa or Auto3m, as they will provide free customer service and information to official unit (type D interface) owners.
    Unofficial versions with type b / b+ interfaces are not discussed on this forum.
    However in basic terms: -
    You need to get your display in the divorced condition if fitting it with your existing head-unit.
    If fitting pre-married display AND head-unit, then no programming should be required.
    IF the donor display is still paired to donor vehicle, then you need the donor vehicle's audio pass / car pass number to allow you to divorce it. And even then this does not always work, unless using Tech2 / Tech3 / TIS2Web.
  1. can a facelift satnav stereo and screen be fitted to a preface half canbus car?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2012, 00:19
  2. CD70 screen in a 04reg preface half canbus
    By andyman201 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 14:43
  3. wipers now think home is half way up the screen !!!
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 13:47
