Thread: fuel and temp gauge not working
    Aug 2007
    somerset
    Default fuel and temp gauge not working
    hi all
    driving my signum 1.9cdti (150)elite today i noticed the fuel and temperature dials at zero.....as both have stopped working could it be a fuse for both?....and if so does anyone know the wareabouts and number of that fuse....any info would be very much appreciated..thanks...kev.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Check fuse 17 at the passenger end of the dash board.
    Aug 2007
    somerset
    i have just inspected fuse no.17 visually and it looks fine...there are 3 fuse compartments according to my handbook....i have pulled out each individual fuse and inspected it as there are no fuses specific to the fuel gauge.....funny thing is i think the temp.gauge has stopped working also....any ideas guys?
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Was the Temp gauge working ok before? Could be that the thermostat has failed. What Stereo do you have? You can check the Temp in the menu of some of the higher spec stereo's, that may give you a clue if the thermostat is working ok or not.
    South east
    The temperature gauge needle won't work until the temperature reaches 70, and if your thermostat is stuck open and cooling the engine too much, the needle will take a long time to move, so you have to be sure that the engine is definitely warm enough for the needle to have supposed to have moved. Does the needle stay still even when the engine has been running for a while and you're stuck in traffic?
    Aug 2007
    somerset
    just been out for a drive at it appears the temp gauge is working (although barely).....i need to focus on the fuel gauge...i also have an onboard computer/sat nav..but that is just saying ''---F''.....can anyone tell me where the fuel sender unit is located?
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    If you lift the rear seat you will see a panel that gives you access to the fuel pump, sender unit should be there in beside the pump.
    Aug 2007
    somerset
    found it.....i jacked the signum up today to inspect for any loose wires...i found a connection block with a brown and a blue severed wire...must have hit a stone or something...dunno....rejoined wires and hey presto, it all works....i wonder how much a garage would have charged for that?....anyway...thanks chaps.
  1. Fuel Gauge not working
    By m2yuout in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2013, 00:59
  2. fuel gauge not working F miles ?
    By Chriseyb in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 21:06
  3. fuel gauge not working signum
    By superjetandy in forum Troubleshooting
    Last Post: 28th February 2011, 15:45
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Engine temp gauge not working ???
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 21:36
signum sender unit access
vectra temp and fuel gauge not working
vauxhall vectra 1.9 cdti temperature gauge not working
vauxhall corsa petrol and temperature gauge not working
