Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: need advice white smoke
    Lincoln
    Default need advice white smoke
    Hi all and hope you can help me
    ok so here goes i have a vectra c 2002 model 2.0 dti every time i start car in morning big cloud on white smoke car gets warm goes away..park car at work at say 11am and leave work around 6pm same again first start big cloud of white smoke,also my temp gauge does not get warm until say im sat in traffic then starts to creep up never overheats tho took it vauxhall and they said theres no EM Light so there's nothing wrong B*llS**T!!
    the smoke smells like oil or diesal!! defo not sweet like antifreeze also no loss in power and start first time no problems
    So my guess is it either
    • Headgasket
    • Valve Stem Seals
    • EGR Valve
    • Turbo ****ed
      Does any one know what's up or the symptoms of above have failed
      Many thanks
    Norwich
    Trim : SXi
    Engine : 2.2
    Head gasket is easy to check if you take the oil cap off and dip stick if its creamy the head has gone or going
    Turbo will smoke under acceleration and won't go away once warm
    EGR normally produces black smoke (I think)
    Lincoln
    not creamy mate just black oil,,the smoke get worse when u boot it only when cold,defo white smoke maybe piston rings?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check glow plugs
    Is it using any oil?
    Dec 2011
    Seaham
    Condensation in exhaust? Take it for a good long run to get the exhaust really hot.
    Have you noticed the amount of water that comes out of car exhausts now??
    Lincoln
    Quote Originally Posted by Critch View Post
    Check glow plugs
    brought new glow plugs the old ones where fine so the garage man told me when he serviced it i have not needed to top it up no..and nothing under car when parked is doing my head in lol
    Lincoln
    Quote Originally Posted by Ben50n View Post
    would there still be condensation on a warm day?? i havent look for water tbh when the best time to look ?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I'd stick new glow plugs in.
    If it's not using oil it won't be valve stems.
    Lincoln
    its got brand new ones in mate NGK ones
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Quote Originally Posted by Madmarky01 View Post
    Had a fiat coupe 20v turbo a few years ago and had the same symptoms,it was turbo oil seals m8
  1. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  4. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
