Results 1 to 2 of 2
Thread: Starter Motor
    Full Member dezzyb66's Avatar
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Engine : 1.9cdti 120
    Default Starter Motor
    Has anyone on here changed a starter motor on 1.9 cdti 120 or a 150 and how hard was it cheers dez
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by dezzyb66 View Post
    Sorry for delay in replying only just seen your post - did mine a couple of weeks ago on a 120 - easy enough to do just 3 bolts and 2 electrical connections - main problem is gaining access to the three bolts holdin it on. The top one is difficult to find for starters and I removed the EGR valve to get a better view of where it was - also took out the battery and battery box for better access. The other two bolts you get from underneath as well as the two electrical connections. Get back if you need further help.
    Oh - the 150 starter motor is slightly different than the 120 - so make sure you get the right one.
  1. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  2. Starter motor help.
    By 123rado in forum Engine & Drivetrain
    Last Post: 6th January 2012, 21:30
  3. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
