Thread: seased rear brake piston
    Regular Member leedrummond's Avatar
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Engine : 1.9 CDTI 8v
    Mileage : 150,000
    Exclamation seased rear brake piston
    Hi. I am replacing all brakes and pads on my car this weekend. I have replaced fronts with no problem. I have come to do passenger side rear put on the disc no problem. Come to fit new pads and I can't compress the piston to fit the new pads. I have tried leverung it but seems so solid. also loosened bleed valve and no joy. Any pointers or help will be appreciated.
    Lee
    Nov 2010
    East Midlands
    Trim : design
    Are you trying to push the pistons back in - you can't - they have to be wound back in with a special tool - or some have managed to do it with a long nose pair of pliers. There are four locating holes on the face of the cylinder - you need to push the piston in at the same time turning it.
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Ahh I see. Thank you very much for that. This special tool is it available from anywhere open on a Sunday
    Nov 2010
    East Midlands
    Trim : design
    Most car accessory shops will have them - I think Halfords did them at one time - I bought a whole set like this on Ebay http://www.ebay.co.uk/itm/19pc-Brake...ht_2887wt_1037 - makes life a lot easier - I see you are in the Potteries - if you were a bit closer you could borrow mine.
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Quote Originally Posted by alcutler View Post
    Ahh cheers mate just spotted one on halfords site but priced at 32 quid typical halfords price haha. Will ask a few mates locally if anyone has one as I see that collection you linked to has different sizes
    And halfords only shows one. Thanks for pointing me in the right direction now anyway.
    Nov 2010
    East Midlands
    Trim : design
    Thats like a universal kit that does quite a few other cars as well as the Vectra. There are quite a few listed on Ebay. Have you tried long nose pliers - you put the end into two of the holes in the piston and screw it in - sometimes its quite easy to turn the piston - if not you need the tool
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    will give it a go tommorow i had packed up by the time i posted so will try it and fingers crossed the plyers method will work, if not i have sourced someone who has the tool i can borrow on monday so should all be sorted :-) thanks again for your help. i was beginning to think it was jsut seased as i have never come across this type of piston before,
    lee
    Jul 2009
    Brighton
    I bought a Laser one, and it did not fit. Spent ages filing the pins down so they can locate in the two indents. PITA!
  1. Is the seal for the piston on the rear brake calliper glued on ?
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 18:47
  2. Rear brake pads don't fit holes in piston
    By sharp114 in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2012, 16:49
  3. rear brake piston
    By guitarbaz in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2010, 16:44
  4. rear brake piston rewind
    By Troutfisherman in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 19:59
  5. Rear Brake Piston - turns but won't push
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 13:28
