Thread: Steering Fault
    New Member samboy143's Avatar
    May 2012
    telford
    Default Steering Fault
    Hi folks, I was wondering if anyone could shed some light on the fault i have,
    Whilst on the ramp i had my front near side wheel off looking at the brakes and bearings, to gain a little more access i tried turning the steering wheel anti-clockwise, forgetting that i had a chock stopping the offside wheel moving.
    With the car back together i took it off the ramp and immediatley found something wrong with the steering.... it is very heavy turning all the time both left and right.
    Does anyone know if its the steering pump i have knackered or damaged anything else?
    Nov 2010
    East Midlands
    Trim : design
    Wouldn't have thought that would have damaged the steering pump - is your pump mounted on top of the steering pump - are you sure you have not disturbed the cables that connect to the pump - there are a couple of heavy duty ones that run into a multi plug that plugs into the steering pump that can be loose and give a bad connection. Check that its pushed home fully.
    Any warning lights on your dash?
    With the engine idling, can you hear the power steering pump?
    May 2012
    telford
    Cheers, il have a look tomorrow when i can get it n the ramp again, and ill let you know
    You should be able to hear it running, without any need to use a ramp
    Simply switch on the engine, then gently turn the steering (12 to 11 o'clock or 12 to 1 o'clock) and you should be able to hear it
    May 2012
    telford
    I had a look at it at all angles, found no leaks and nothing loose, although fluid level was lower than normal.
    I took it for a short drive and found the fluid had gone right down, and noticed the rubber boots for the tie rods were wet, so seal/seals have gone instide the steering rack.
    Mine has gone the same way, just after the Power Steering Pump was replaced
    Normally when the fluid is low, due to a leak, the pump switches itself off
    As for a replacement, get your blankety blank cheque book out
    I might not be bothering and it might be the end of my car;
    Service is now due
    MoT now due
    Front brake pads and discs
    Replacement Power Steering Rack
    Residual value of vehicle £1100...
    Spending £1100 on the above, it's really borderline
  1. Steering Fault
    By ftm100 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 20:24
  2. steering fault
    By andy696uk in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 16:22
  3. Steering Fault
    By AOL in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2010, 18:41
  4. Steering fault
    By Steven in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd December 2007, 18:20
  5. Steering Fault
    By biglardyboy in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 18:21
