My 56 plate 2.2 direct Design Estates battery has been getting weaker and weaker and I think its about time to replace it. Is it a straightforward swap out or am I likely to get in to problems with having to reset things?
R.
R.
Depending on what model stereo you have - make sure you have your radio code which will need inputting - and reset the electric windows when battery re- connected. To reset them - ignition on - press 'up' control button until window fully closed and hold button down for a few seconds after window fully closed. Each window will need resetting the same way.
You can adjust them from the drivers control pad - the windows have a one touch close facility (presuming yours has this fitted - but I would think so) if you don't reset it you can still close the window but you have to keep your finger on the button until fully closed - once reset you just press and release the up button and the window will go all the way up to the close position. Its a memory thing that is lost when you disconnect the battery.
Thanks a lot
The door locks will also reset to the default locking/unlocking settings. 1 touch opening, anti hijack etc.
Yes just change it,sometimes you have to do the electric windows but I've never had to yet--[reset the window switch's]----Dave
@dave1419
thanks for that dave, saves the worrying bit ha ha
