Likes Likes:  1
Results 1 to 10 of 13
Thread: Battery Replacement - Anything to look out for
    Jul 2009
    Norwich
    Default Battery Replacement - Anything to look out for
    My 56 plate 2.2 direct Design Estates battery has been getting weaker and weaker and I think its about time to replace it. Is it a straightforward swap out or am I likely to get in to problems with having to reset things?
    R.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Depending on what model stereo you have - make sure you have your radio code which will need inputting - and reset the electric windows when battery re- connected. To reset them - ignition on - press 'up' control button until window fully closed and hold button down for a few seconds after window fully closed. Each window will need resetting the same way.
    Jul 2009
    Norwich
    Quote Originally Posted by alcutler View Post
    Thanks. Found radio code. Can I reset all windows from driver control or do they need doing from each windows individual control? Seems odd to have to reset windows. Why is that?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    You can adjust them from the drivers control pad - the windows have a one touch close facility (presuming yours has this fitted - but I would think so) if you don't reset it you can still close the window but you have to keep your finger on the button until fully closed - once reset you just press and release the up button and the window will go all the way up to the close position. Its a memory thing that is lost when you disconnect the battery.
    Jul 2009
    Norwich
    Thanks a lot
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    The door locks will also reset to the default locking/unlocking settings. 1 touch opening, anti hijack etc.
    5 Post(s)
    Depending on what model stereo you have - make sure you have your radio code which will need inputting.
    A 56 reg will be full canbus and therefore won't require the code following a power interuption.
  8. Likes john_k_sri liked this post
  9. #8
    Regular Member MUNGIS's Avatar
    Aug 2012
    Central Scotland
    Vehicle : 2005 Vectra 2.2
    Trim : direct
    Engine : 2.2 Auto
    Hi guys, does this mean i can swap over a new battery in my 2007 CDTI SRI without losing radio etc, or using my portable battery connected to cigar lighter ?
    thanks
    MUNGIS
  10. #9
    Full Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    5 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Yes just change it,sometimes you have to do the electric windows but I've never had to yet--[reset the window switch's]----Dave
  11. #10
    Aug 2012
    Central Scotland
    Trim : direct
    Engine : 2.2 Auto
    rolleyes
    Quote Originally Posted by dave1419 View Post
    @dave1419
    thanks for that dave, saves the worrying bit ha ha
  1. Car Battery replacement
    By Casper85 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 20:35
  2. Vectra C battery replacement problem
    By lilaclily in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2012, 19:17
  3. key fob battery replacement
    By cranny 27 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:22
  4. battery replacement
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 00:05
  5. Battery Replacement???
    By B19CBB in forum Engine & Drivetrain
    Last Post: 21st May 2008, 19:32
