Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Alarm going off randomly
    Aug 2007
    newport, South Wales
    Default Alarm going off randomly
    Hi
    i hope someone can help me with an issue.
    I have recently had a tyre changed ( drivers rear) and since then, the alarm has gone off at random times.
    I've never had a problem with the alarm and changing tyres before
    Do you think there is any thing related to this and the alarm?
    Also is there a way of finding out which sensor has triggered the alarm?
    Roger
    Regular Member John Bishop's Avatar
    Oct 2010
    You getting check safeguard on the screen?
    South east
    Is your car an estate or hatchback?
    Aug 2007
    Its a vectra C 1.8 ls hatchback
    What is check safeguard, on what screen?
    thanks
    Quote Originally Posted by bishbang View Post
    Not if he hasn't got the system check, or only the basic stereo display.
    Feb 2012
    liverpool
    could be your battery on its way out
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    wonder if its got anything to do with the tilt sensor ...just a thought .not sure whether it would get picked up on a tech2 or not .
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    or it might be heated rear screen, iirc the alarm checks the screen elements in case of breakage, is you rear heater working ok, might be worth checking the connections at either side
    Aug 2007
    Rear screen heater works ok.
    I thought it might be the sensor under the bonnet, so adjusted the bonnet to shut tighter and seemed to work for a while until yesterday.
    Alarm still randomly going off.
    It seemed to start after I had the rear driver tyre changed.
    Is there anything around there that could be at fault?
    thanks
    May 2012
    chelmsford
    As taxidriver said battery can start to be getting weak
  1. Alarm goes off randomly-have fault codes
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2012, 12:24
  2. Alarm Randomly going off???? - Vectra 2006 Estate
    By TheSnowMan in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 14:13
  3. Stereo randomly changes channel . . .
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2011, 22:32
  4. Vectra C starts then randomly stalls
    By Ardent in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 09:37
  5. Loss of power randomly on a SRi 150
    By jrwilshire2003 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 01:34
vectra c how to change power sounder site:www.vectra-c.com
