Results 1 to 10 of 15
Thread: Brake pedal creep - 2.0T - MOT failure!
    Sep 2011
    Hampshire
    Default Brake pedal creep - 2.0T - MOT failure!
    I have recently changed the pads and discs prior to my MOT.
    The car has failed the MOT for "Brake pedal creeps down while the pedal is held under pressure".
    The brakes operate efficiently and the car stops normally. Once the car has stopped the pedal creeps almost to the floor without much effort.
    With the engine off the pedal can be pumped 'hard' and then has about 1cm of movement under normal foot pressure and 1in of movement under heavy foot pressure.
    If I maintain the pedal pressure and start the engine, the pedal goes down with normal pressure to 1/3 travel and then creeps under light pressure almost to the floor. When braking the car stops at about 1/3 pedal travel and then the pedal continues to creep towards the floor. The pedal seems make a bit of a hissing noise when pumped - not sure if this has got worse or not.
    I have replaced the brake fluid with no improvement. My car has never leaked brake fluid.
    Has anybody encountered this before? I understand that components which may be at fault are the master cylinder, servo or vacuum pump. Can anybody please tell me the best way to test and eliminate each component?
    Thanks in anticipation!
    Dec 2011
    fareham portsmouth
    i hear this is correct look for diesel creep on the internet then take it to the guy who mot'd your car
    Regular Member Mopar Man's Avatar
    herts
    If since youv changed your pads, then i suggest you have worn brake discs. The brake pads will not seat down on an uneven disc, cousing a low pedel.
    Dec 2011
    fareham portsmouth
    mopar mate
    he has new disc too well he said in his post diesel creep is natural as you dont have a servo as such just a bleed off back to the system look it up loads on google
    East Ayrshire
    Trim : SRI XP1
    Given that it's a 2.0t it isn't going to have diesel creep since it runs on petrol. It could be they need bled, an internal seal has flipped etc. there a few things. One of the flexi hoses going to the caliper could also be ballooning. Might be best biting the bullet and popping it in to a mechanic for a quick diagnostic
    South east
    Has he got a diesel or petrol though? "2.0T" sounds like the Z20NET, but is he referring to the 2.0 DTi???
    Sodding Typical on Sea
    I am suspecting its a petrol and has a servo or master cyl issue
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Does it do it with the engine off?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Doesn't the NET have a Vac generator bolted to the side of the Cam cover just like the CDTi's, so could the term Diesel creep apply to the NET also?
    dublin
    had this happen on my 1.8xe recently. the master cylinder has been replaced and the problem seems to be still there. Next is the servo to see if that solves the problem.
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. brake peddle creep
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2012, 22:27
  4. Brake pedal creep Signum 2.0T (not diesel)
    By olajon in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2010, 12:13
  5. MOT fail due to brake pedal creep
    By baztheman in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2009, 15:26
