Results 1 to 10 of 13
Thread: Had Windscreen changed now have "general glow plug error"
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Had Windscreen changed now have "general glow plug error"
    1.9 CDTi 150
    2005 preface lift
    How can having a Windsreen replaced end up giving me a "general glow plug error"?
    Car has been running and starting fine with no issues.
    Went to start the car several hours after getting the windscreen changed and the fault appears.
    What could have been damged or is it a total coincidence which I doubt.
    The light goes out once the car has warmed up a bit.
    Will check the resistance on the glow plugs in a while and report back
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Weired one that fella maybe coinsadance
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well checked the resistance and the results were;
    1.1
    1.1
    7.6
    NIL
    So two were faulty!
    Sprayed them with penetrating oil and then went to VX to get the plugs (£50 for a set at GM employee prices)
    Sprayed them again and left them for another hour.
    All four came out without any problems
    It seems the issue has been solved, need to do the missus Signum now as it has the same issue as well, bizzare..........
    Many thanks to Telly Addict for the "How 2"
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Nothing suprises me with the electrics on the Vectra - Last week I changed all four headlamp bulbs with Nightbreakers. First time I started the car got a bulb warning light on the dash - now you would think it would be a faulty connection on or around the lights I had been working on - no it was a brake light bulb that had blown and I know it was working perfectly before I did the front lights
    Dec 2011
    fareham portsmouth
    i started mine today and it beat me i cant find no vids or info how to do it i removed the egr then removed the wire started to turn them no problem then thought how the hell do they go back in how much does this cost to get a mechanic to do as this is the only car we have cheers all
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by bobbleheadbarney View Post
    If you look in the "how 2" section you will find this http://www.vectra-c.com/forum/showth...gs-on-1-9-CDTi
    Strangely enough they go back the same way they come out
    Should take less than 10 mins to do
    Dec 2011
    fareham portsmouth
    i wish mines the 120 behind the block its a bummer
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Sorry bud thought you had the 150 like me
    Dec 2011
    fareham portsmouth
    no need some one to hold my hand i started it then bottled out they seem to bee loose when i tried to undo them so i think they will come out just worried they wont go back how much shpuld i pay to get this fix cheers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well the hardest part is getting them out and you are most of the way there doing that. The easy part is putting them back in, just put a smidgen of copper grease on the thread. Have you checked the resistance to see which ones are faulty?
  1. glow device general error
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 14th January 2013, 22:59
  2. P0380 Glow Plug/Heater Circuit "A" Malfunction
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 9th March 2012, 21:38
  3. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  4. glow plug general fault.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 7th April 2011, 07:53
  5. Glow plug general error p0380-08
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 27th June 2010, 19:16
