Thread: Brake lights still available without ignition ?
    Feb 2012
    Willenhall
    Trim : Elegance
    Engine : 2.0 DTi
    Year : 53
    Default Brake lights still available without ignition ?
    I've had a '53 Vectra Elegance for about a year now and I've only just noticed that the brake lights are still 'available' even with the ignition off ? I even sat in the car, turned off the ultrasonics, deadlocked it and waited for the alarm to set before trying it again and the brake lights came on when I pushed the pedal. Is this normal for a Vectra C as I've never seen it on a car before ?
    Barrow In Furness, Cumbria
    Think its the same on mine. They might stop working after 30 mins (?) like the radio / interior lights are left on when the ignition is off?
    Feb 2012
    Willenhall
    Trim : Elegance
    Engine : 2.0 DTi
    Year : 53
    Ok, seems strange.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Its normal its the same on the Insignia
    Quote Originally Posted by Mark Evison View Post
    Its normal
    Some of the old Rovers (200 model?) were the same, along with countless other cars that have brake lights constantly powered up.
    Feb 2012
    Willenhall
    Trim : Elegance
    Engine : 2.0 DTi
    Year : 53
    Ok cool, one less problem with mine to investigate.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    Think its incase you brakedown and our being towed your lights still work even if your engines switched off
    Unless you're being privately towed, most breakdown companies will either use a trailerboard on the back of your vehicle that's hooked up to their tow socket, or simply load it on a flatbed.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    Very True, forgot about that
  1. No lights working with ignition off -2006 Facelift 1.8 Life
    By skier in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 15:54
  2. brake lights work without key in ignition
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 13:27
  3. side lights come on with ignition?
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2012, 22:43
  4. rear number plate lights on all time when keys in ignition
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 13:56
  5. Ignition Lights
    By jka in forum Engine & Drivetrain
    Last Post: 11th August 2005, 21:35
