Results 1 to 3 of 3
Thread: Car will not start after new timing chains.
    Apr 2012
    Plymouth
    Default Car will not start after new timing chains.
    As the title says. The car is a 2.2dti.
    What it is, it that i can not get my engine started at all. I have just set the timing with the timing tools so i know its spot on although now its not starting im doubting that! The car was running before i stripped it down to change the chains and it wont start again now. I have i had the wife crank it over with the diesel lines into the engine loose and then tightend up once fuel was coming through. Leak off pipes look ok but changing them this morning. It feels like it wants to start but doesnt!
    Any other ideas please as im drawing a blank.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Air lock??...fuel pump primed??
    Apr 2012
    Plymouth
    I re-checked the timing and its spot on. I checked the fuel filter and its air tight. I had the nut loose on the fuel lines into the injectors and tightend them up in turn when fuel came out. Its got new leak off pipes.
    Majorly fed up with it now. Its starts for a split second and just cuts out. Runs on ez-start but not on its own.
  1. 2.8t v6 timing chains.
    By nick150 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2012, 22:33
  2. 2.2 timing chains
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 18:50
  3. 2.2 direct timing chains.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:40
  4. Are timing chains a non standard item?
    By Karin B in forum Petrol Engine related
    Last Post: 5th May 2009, 12:08
  5. Anyone know how to fit timing chains? 2.2
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 2nd August 2008, 22:17
vectra wont start after timing chain change
