Thread: Rear lower control arm
    Jul 2009
    Brighton
    Default Rear lower control arm
    Replaced my rear arb bushes prior to having a Hunter 4 wheel alignment done. Alignment went well, except they couldn't adjust the camber on the rear right. Turning the bolt had no effect. Is this the lower control arm?
    Anyone had any experience changing them? Easy/cheap????
    Quoted £162 to replace and adjust alignment.
    Jul 2009
    Brighton
    Had another look, and it's the rear lower control arm additional.
    Anyone replaced one of these?
    Jul 2009
    Brighton
    Anyone?
    South east
    I can't picture which arm you mean - howabout a photo?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    The one that the spring sits on ??
    South east
    Is there camber adjustment on that arm though?
    Jul 2009
    Brighton
    Have a look at here
    http://opeloem.com/vauxhall/signum_2...nsion_arm.html
    It's item 22. It looks like a bar in the picture, but is actually box section. It sits in front of the large rear control arm and controls the camber (the inner bolt has a eccentric washer for adjustment).
    Only two bolts, so shouldn't be an issue, just wanted some advice.
    Jul 2009
    Brighton
    Just ordered on from carparts connexions £20, much cheaper than local Vx who wanted 50.
    P.N. 13204112
  1. Rear Lower control arm
    By cookie in forum Handling & Braking
    Last Post: 31st July 2012, 11:41
  2. rear lower control arm bush
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 13:32
  3. Lower control arm signum
    By arkhan78 in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 10:59
  4. lower control arm with ball joint, help
    By wrayballs10 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2009, 20:13
vectra c rear eccentric washer
