Results 1 to 10 of 17
Thread: rear ride height
    Oct 2010
    nr leeds
    Default rear ride height
    hi all
    i'm after lowering the body height on the back end of my signum.
    since i went to 225/45/17 tyres theres a huge gap between the arch top and tyre can anyone suggest whats the best plan of attack.
    was thinking sri estate springs as i only want to lower the rear the front is fine.
    any suggestions would be greatly appreciated.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Your tyre's are too small for 17" wheels They should be at leased 225/50/17 to give the same rolling circumference. 225/45/ would be the correct size for 18s
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    225/45/17 or 215/50/17 are the correct ones.
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    225/45 is the correct optional size for a 17" wheel, according to the manual though. Been looking at this as I will need new tyres this year at some point and 215/50's are silly prices.
    Trim : Sport
    Engine : Petrol
    Vauxhall Vectra Expression, LS, Club, EnergyTyre size: 215/55 R 16 (standard)
    Vauxhall Vectra Sxi, DesignTyre size: 215/55 R 16 (standard) 225/45 R 18, 235.35 R 19 (options)
    Vauxhall Vectra Elire, Sri, GsiTyre size: 215/50 R 17 (standard) 225/45 R 18, 235.35 R 19 (options)
    Engine : 2.2 Direct
    Quote Originally Posted by DTI-Steve View Post
    Yes thats from factory.. but the other are in the manual, and in the "type approvement"
    Trim : Sport
    Engine : Petrol
    225/45/17 gives a different rolling diameter so the speed-o will be out. Have a look at the link mate put in the size tyre you took off then compare with the ones you have on then go with the closest match, I think there is a 2 or 3% tolerance where the speed-o is concerned.
    As Knep says, take a look at your manual. There are different variations that can be used with different sizes of wheel.
    http://www.etyres.co.uk/tyre-size-calculator.htm
    Engine : 2.2 Direct
    Your speedo is also out the more the tyre is worn and you can always set it correct in the IPC. and the only one to change is if you go to 19" wheels.
    Quote Originally Posted by mickyp3 View Post
    This is the price you pay, along with others issues, with swapping from 215/50R17 to 225/45R17
    The reason for the apparent gap is the even lower profile of this tyre
    It is more obvious at the rear, but eventually you will get used to it
    Do you still have 215/50R17 on the front, or have these also swapped over?
    Oct 2010
    nr leeds
    All 4 tyres are 225/45/17
    speedos been recalibrated with tech2 to option2 which is the correct setting for the tyre size.
  1. Rear shocks fitted and ride height tweeked
    By A5TRA in forum Quick Photo Album
    Last Post: 15th April 2012, 16:25
  2. ride height
    By pidge in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 17:59
  3. SRI ride height ??
    By Mickyboy in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2010, 12:05
  4. GSi ride height
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2008, 18:21
  5. Ride height
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2007, 22:13
