Results 1 to 3 of 3
Thread: When will it end!!!
    Regular Member John Bishop's Avatar
    Oct 2010
    Eek When will it end!!!
    Now I know that I will have to get the dmf, clutch and bearing and csc done at the end of the month which is not going to be cheap but I don't believe this.
    Had a knocking noise from underneath at the back. Had a check on getting home and found the rear bracket of the centre section of the exhaust has completely corroded. Cheapest replacement centre pipe section through the usual outlets is £340. So searched the net as sod's law if I replace that then in a few weeks no doubt another section will need doing. So I tried looking for a replacement system from the cat back in stainless steel. Rang several places who supply or manufacture them and I knew it would cost as it is the 3.0 V6 CDTi. However as it is an estate that ruled some out. Then because it has a dpf that killed the rest of them. Anyway am going to Powerfow in Nottingham tomorrow who hopefully can do a cat back system but I am looking at around £700. Add that the other jobs mentioned earlier in the post and in the next month it is going to set me back £1500!!!
    Jesus, talk about a house being a money pit
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Just get another bracket welded to the centre section if there is nothing wrong with the actual exhaust. I just used galvanised wire and it all still holding perfectly.
    Oct 2010
    Thought about that but it has been on over 7 years so I may as well swallow the bitter pill
