Thread: 1.9 CDTi Oil changing
    Sodding Typical on Sea
    Default 1.9 CDTi Oil changing
    I seem to recall that it is not possible without a ramp due to the under side cover plates?
    Is it a job I can do with the car on axle stands? I fancy an inter oil drop at 10K which is now-ish.
    thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by Derek Mc View Post
    thanks
    Yip.
    Get it high on axel stands and you will be able to bend the flap of the undertray back round.
    @10K I would be defo doing a oil change.. Dont agree with the 20K changes that they say
    Thanks chum.
    I know what my task will be for the weekend!
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Im doing mine this weekend too, my undertray is already off tho from when I had the new flexi pipe fitted. Not looking forward to putting the undertray back on tho, going to be a right pain in the butt
    Nov 2010
    East Midlands
    Trim : design
    Never had the tray on - mine came without one and I haven't bothered getting one. Can't see the point of them other than a slight reduction in engine noise on the diesels - the fasteners have a very limited life and you can't access anything when its on. Had one on my Mondeo but that was soon taken off.
    gwent
    Did my service last week end I took the under tray off as when I undone the four screw for the oil hatch flap it started to crack. Plus I could touch up the subframe with some paint as well
    scottish region
    As said Derek if u get it high enough on axle stands you will be Kl
    Quote Originally Posted by DAVIDD88 View Post
    I could always use lazy plan B,,,,, drop the flap dangle edge over basin, remove plug, let it rip
  1. Changing GTi-6 for a Vectra 1.9 cdti 150 Elite
    By davidh5555 in forum Introduce yourself.
    Last Post: 21st April 2013, 01:27
  2. Air Con. Changing Condenser/dryer on CDTi 150
    By phil9471 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 04:15
  3. Changing a 1.9 CDTi (120bhp) EGR?
    By lee gsi in forum Engine & Drivetrain
    Last Post: 23rd February 2011, 15:54
  4. 1.9 CDTi - changing fuel filter
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 11:22
  5. Changing the thermostat on a cdti 120 8 v....
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 22:25
