Thread: Are they the same?
    Jun 2011
    Kent
    Default Are they the same?
    Looking at the rear bumpers on an Elite and an SRi, it is only the bottom removable spoiler part that is different and the rest is the same.
    I want to fit the VXR rear spoiler section on my Elite and of course the central diffuser with twin pipes cutouts too.
    Am I right on the above or will run into troubles?
    Liverpool
    You need the Sri bumper pal, the elite bumper hasn't got the cut out for the central insert
    You could try and cut the bumper to fit but I would personally just get the Sri bumper
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    I was also thinking this way once, but u defo need to get yourself SRi bumper
    Jun 2011
    Kent
    Thanks guys but this doesn't really answer my question.
    Ill be clearer; there's a separate strip running all the way around the bottom of an Elite bumper (the spoiler) & it's removable.
    The SRi one is too, so in theory I could possibly get an SRi spoiler & central dual exit exhaust insert & fit to my bumper as the rest of the bumper looks no different.
    This appears to be the case but I just wanted to check before buying both parts.
    Sep 2010
    I didn't realise the lower section of the rear bumper was removable on any model. I'm sure our standard SRI is all one piece.
    scottish region
    Not removable on Sri its part of the bumper
    Nov 2009
    manchester
    The bottom bit of the sri bumper is not removable as it is on the elite, the one on the elite is the same as a low spec vectra but with the bottom part colour coded.
    Regular Member Fash's Avatar
    Doncaster
    There is actually a piece like the lower part on the sri bumper on ebay
    http://www.ebay.co.uk/itm/VAUXHALL-V...#ht_1187wt_905
    so theoretically if the lower part of the bumper comes off you could attach one of these and then fit the vxr bit in the middle...
    Does the lower part of the bumper come off on the elegance ??
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    I have the same query, don't want to shell £100+ for a colour coded sri bumper just to have the cut out if I can replace the spoiler. There are quite a few spoilers out there that look like they're off SRI and the "rest" of the bumper looks identical, comparing both side by side, so the only issue is regarding the attachment clip points...
    Regular Member bigdave1701's Avatar
    York
    The part in that link is a replica XP2/VXR bumper trim. You still need the SRI bumper as it's that, that holds the cut out. The XP2/VXR skirt is then bonded over the top of the bumper!
