Results 1 to 10 of 16
Thread: Stiff Gear Change
    Regular Member John Bishop's Avatar
    Oct 2010
    Default Stiff Gear Change
    Some advice please guys. Have noticed in the last couple of months that changing gear is no longer a nice smooth single step process. It is a clear 2 step proces, first from the current gear then into neutral and then into the next gear (this is regardless of which gear it is in) and sometimes it has to be pushed into the next gear very firmly. In addition when pressing the clutch pedal it does sound rattly. Finally when in reverse it is very juddery.
    Reading the forums does this sound like the dreaded DMF failing or the clutch?
    If it is either I will obviously get them both replaced but if it is the clutch should I also get the bearing and csc done too?
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Talking
    Yes i had same problem about six months ago i had the dreaded rattle so i changed the clutch flywheel and bearing plus dont forget the bolts
    Oct 2010
    Cheers Driver. What about the csc and bolts ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    Oct 2010
    Cheers vectra ste. Any views on the csc ? Bolts!???
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    Quote Originally Posted by bishbang View Post
    ive been on the vectra c site for a while now and never came across csc and bolts because mine is petrol
    im sure someone will come along and tell us
    Oct 2009
    South Yorkshire
    To be honest i bought the full kit from euro parts, i am sure it came with clutch , flywheel , bearing but i had to go to deals for the bolts. what hold the flywheel due to the old ones looked streched. Hope this helps you.
    Oct 2009
    South Yorkshire
    Oct 2010
    Update.
    Picked the hearse up after a respray repair. Started to pull away and it felt as though the brakes were stuck on and there was a slight knock. Anyway pulled away and since then the gear change has been sweet and smooth, also it is no longer juddery in reverse? The clutch still makes a noise when the pedal is pressed so I have it booked in to have the clutch, bearing, csc and dpf done. Am a bit baffled by this though?!
    Oct 2010
    Just had a message to ring the place replacing the the above. They can only locate one clutch in the UK for the hearse and that does not come with the bearing. Unfortunately it is at Vauxhall in Luton and will be an extra hundred quid. Have therefore cancelled it as the hearse is ok at the moment. Just need to sort out the rattle/knock coming from the rear.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Stiff gear change when cold - fluid changed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th December 2012, 14:58
  3. Stiff Gear Change
    By sheddy in forum Engine & Drivetrain
    Last Post: 24th February 2012, 12:07
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Stiff gear changes
    By James7 in forum Engine & Drivetrain
    Last Post: 17th April 2007, 19:45
