Thread: Smell of fuel when driving
    May 2012
    WEST YORKSHIRE
    Default Smell of fuel when driving
    i have an 05 cdti auto vectra and have a smell of fuel in the cab,coul dthere be a split in the manifold causing it to come through the air vents in the cab? thanks
    Regular Member poves's Avatar
    lancashire
    Quote Originally Posted by leek View Post
    Strange on a derv , would of suspected it to be petrol if your getting a whiff of something .
    I must say your username is rather "apt"
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It WILL make you drowsy, it has happened to me.
    Prob cause is a split rubber pipe which returns the unused diesel to the pump.
    They are easy to change.
    Needs sorting asap.
    http://vectra-c.com/forum/showthread.php?t=152194
    May 2012
    WEST YORKSHIRE
    thanks for that guys
    where would i get the pipe? ebay etc? wheres it located and how would i fit it.
    cheers tony,i had a thuming headache this morning after driving 2 hors last night
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    I would buy the kit as mentioned in the How2.
    May 2006
    scotland
    Is it unburnt diesel or is it exhaust fumes you are smelling? Sorry for asking but if it is exhaust, it could be a split flexipipe at front bottom of exhaust or leaking swirl valves (if it is a 150 bhp). If unburnt diesel, it may also be an injector not sealing properly. I had this and I got fumes in the cabin when accelerating hard? It was injector four as I could see all the solidified diesel round that area. It has sealed itself over the years and no more whiffs.
    May 2012
    WEST YORKSHIRE
    seems like exhaust fumes willie.whats the best way to sort this please? thanks
    May 2006
    scotland
    The easiest thing to check first is your exhaust system. If it is the front flexipipe, then you will hear it and see soot round that area. Next is the swirl valves. Yours being a 16v (according to your profile), will have swirl valves. Take the top plastic engine cover off and with the engine idling, look for tell tale exhaust smoke coming from the swirl valve area (there are loads of pictures and descriptions on this forum for these swirl valves, just do a search). Also sniff with your nose. If it is the swirl valves, then as a temp fix, you can disconnect the electrical connector of the EGR valve to stop the exhaust gases from entering the inlet manifold. This should stop the exhaust fumes after a few miles. I have glued and sealed my swirl valves (1,2 and 4) as I was getting slowly gassed. I have now reconnected my egr valve. I refused to pay £700 for a new manifold. My car drives just perfect now, no fumes.
  1. Replies: 9
    Last Post: 19th August 2012, 23:16
  2. help 2.2 direct fuel smell in cabin
    By nigelbriggs in forum Engine & Drivetrain
    Last Post: 17th March 2012, 09:06
  3. Fuel light and range driving me potty!
    By Saf_789 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 00:30
  4. Fuel smell
    By paulhb in forum Engine & Drivetrain
    Last Post: 6th May 2010, 10:00
  5. Diesel Smell when stationary (after heavy driving)
    By Flek in forum Engine & Drivetrain
    Last Post: 28th November 2009, 17:42
