Results 1 to 10 of 11
Thread: Vectra C, 2002, Rear Suspension knocking/creeking noise
    Jun 2011
    YORK
    Default Vectra C, 2002, Rear Suspension knocking/creeking noise
    Right, 6 months ago had rear control arms replaced as rubber bushes had gone.
    Had MOT last month had 2 new rear springs fitted as old ones had snapped, also replaced anti roll bar bushes as there was slight play.
    Everything was fine up until yesterday knocking/creeking noise at the rear at slow speeds and on uneven roads.
    Took everything out of the boot including spare wheel and the noise is still there, creeking noise when pushing rear of car down at back as if it is grinding against something.
    Please help!! pulling my hair out!
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Unfortunatly it sounds like the arms again... Try WD40 just those bushes and see if it goes a little...
    Jun 2011
    YORK
    cheers bud, it is different knocking sound to the arms knocking last time. Maybe right will get some wd out tomorrow. Thanks for the help.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Mine squeeked when bounced on the boot lid, was the "banana" arms in my case.
    Jun 2011
    YORK
    Right couldn't wait sprayed WD everywhere everthing alot better but its like a tapping sound. No creeking but a click noise when pushed quite hard on back end.
    Took it up the road and a lighter tapping sound when suspension under a slow uneven road.
    Read somewhere it could be hand brake as I have it to take for a recall.
    P.s Yes it was the banana arms. Suspension control arms or something rubber bushes at either side.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    You changed the brake pads recently... Is it def from the wheel area and not the boot lid/lock?
    Jun 2011
    YORK
    Definately wheel area, no pads and disc were 18 months ago.
    Ive had a recall from Vauxhall in regard to hand brake hadn't had time to take it.
    Something to do with it unreleasing itself
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    That's the handbrake itself slipping if you don't use the button properly, not brake related.
    Well I'm stumped, can't think what else would rattle as everything should be tight?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    what about the shock absorbers
    Jun 2011
    YORK
    Will have to leave it until father in law gets back from Cyprus.
    Will let you know what the problem is.
    Thanks for your help. Starting to think it might be bushes again as I got the cheap ones from ebay...........................
    Shockers sound ok. Can hear them huffing nicely and the back end retorts quickly.
  1. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  2. Bouncy Rear suspension and creeking
    By s0501291 in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2010, 11:03
  3. Rear suspension knocking noise, help
    By clive3373 in forum General Chat
    Last Post: 8th May 2009, 20:24
  4. Suspension change - now a knocking noise
    Last Post: 5th November 2008, 21:12
  5. Knocking Noise from Suspension
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 13:22
vectra c knocking from rear
vectra c rear suspension knocking
vectra c rear knovking slow speed
2009 vectra c knocking rear suspesion
vectra c knocking rear when pushing on car
vectra c rear knocking
