Results 1 to 10 of 11
Thread: headlight connector fault ?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default headlight connector fault ?
    fitted angel eyes and very happy with them .now a week later all lights on drivers side
    not working .i removed light and wiggled connector and they work intermitemtly
    i refitted origional light to check and it worked fine. now unsure what to do.
    i can try a new connector if available from dealer or send light back and stand postage
    and hope it is the light
    advice welcome.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    At a guess Its the connector and not available from dealer. Mine did the same after a bit. Get a new connector from scrappy and use a connecting block
    Trim : improving
    Year : 06
    after a bit i could stand but after a week im wondering if unit could be at fault
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    Mine does the same. The connector block inside th eheadlight unit is not secured properly and when you plug the connector on it pushes the connector block inside the headlight.
    I got around it temporarily by supporting the back of the connector from inside the headlight by removing one of the bulb covers whilst connecting the plug.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    cheap lights I'm afraid.........and yes mine are copies.....I glued the inside plug back in place - solved the problem
    Trim : improving
    Year : 06
    cheap .....perhaps but still £160 so not sure what to do
    might as well try fixing it if replacement will do same
    thanks for imfo chaps
    Trim : improving
    Year : 06
    double post
    Jun 2009
    bradford
    Quote Originally Posted by mrk View Post
    ok perhaps worded wrongly.............chinese mate so not oem
    Trim : improving
    Year : 06
    no worries mate
    loving what you ve done to your car
    Trim : improving
    Year : 06
    no worries mate
  1. Headlight connector
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 20:31
  2. Removing blue connector on headlight switch
    By Reading1800 in forum Bodywork & Interior
    Last Post: 5th June 2010, 11:04
  3. Headlight connector
    By LEW1S2006 in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2009, 00:18
  4. Anyone check where the headlight motor wires go to on the connector?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2009, 21:13
  5. Headlight Connector/plug
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 19:04
