Thread: Vectra Sri 1.9 150 No power until high revs
    Redcar
    Default Vectra Sri 1.9 150 No power until high revs
    Hello Guys :-)
    I changed my oil the other day and has been a little bit smokey from a little spill on exaust I think after removing oil filter. Today on way back from Shopping I started car up and there was no power and was moving like a snail. There was no problem lights on dash and when it did manage to get high revs it was ok. Engine sounds fine and starts up ok just no power at low revs. Any ideas on what to do? My milage is 80 thousand odd. Thanks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    when was the last time you cleaned the egr valve out
    Redcar
    I dont think it has been cleaned or maybe a couple years ago. Cant remember to be honest. It revs up fine in nuetral and engine sounds like its usual self. Would a clogged EGR cause abit more then normal smoke? Cheers
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    EGR could do with cleaning out, mines like that at the moment, not much power unless rev above 2000rpm
    Redcar
    It was really dangerous to pull out juctions it was that slow. Could of walked faster :-D When it did start moving after a age of foot to the floor it felt fine and could hear turbo.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    here is a few useful how 2s
    http://www.youtube.com/user/Absolute...?feature=watch
    your egr is proberbly full of soot
    others to try are in the vid
    hope this helps
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    It's related to turbo, check intercooler hose pipes. Check throttle body, check boost valve and clean it, remove egr valve and check inside opens and shuts freely, if gives resistances, squire some wd40 inside, not the exhaust area! Then clean egr valve.
    Ensure oil level is ok, make sure it's not on the max. 3/4 full is best.
    Check boost sensor valve hoses as well. There's 2 pipes attached, one to turbo, one to engine and another hose from engine to sensor.
    Redcar
    I could here turbo when need and sounded fine I ment to say. I will check all the bits and pieces you guys have mention. I really appreciate the advice and hopefully can solve this. Wont get chance till weekend as work :-(
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    check this as well
    from another post on here
    Took the car to a friendly local company (Elddis Motors, Durham - recommended) rather than the Vauxhall dealer, for a diagnostic. Turns out there was a split vacuum pipe, which I would never have been able to fathom out. I've included some pictures.
    The red circle on the left is where the fix has been done. Originally there was a short rubber section on the metal tube, with a piece of hard plastic pipe between it and the rubber hose (just like the one in the blue circle on the right of the main picture).
    Anyway, this short rubber section had a split in it, but underneath where it couldn't be seen. You can see in the other pictures how it's perished, probably with the heat, and looks like it's been sucked inwards until it split. This was all going on under the engine cover, out of sight.
    Hopefully this will help anyone who suffers the same symptoms as I did.
    Cheers everyone.
    Engine bay with engine cover off. The areas of interest are circled
    Red circled area. The new suction of rubber hose that has been fitted.
    Blue circled area. The short rubber section looked like this originally, with a piece of hard tube going into it.
    This is how it looked when on. You can see the deformation at the bend due to the heat and vacuum.
    The underside looks like this. A small split.......
    But really a gaping hole.
    After replacing this with new tube the car is back to normal, Hurray!
    Cost of the diagnostic and fix was £47.00. Well worth it.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
  1. high revs no power
    By veccyDaz in forum Engine & Drivetrain
    Last Post: 29th May 2012, 18:31
  2. Loss of power - high revs
    By ac14 in forum Engine & Drivetrain
    Last Post: 19th March 2012, 22:11
  3. No power between 3k-4k and high revs
    By troodon in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 18:53
  4. Can you Help ~ Loss of Power, High Revs
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:23
  5. High Revs and Low Acceleration on 1.8 Vectra
    By RavenRob in forum Engine & Drivetrain
    Last Post: 5th January 2009, 02:20
