Results 1 to 10 of 14
Thread: Uprated 1.9CDTI injectors....
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Uprated 1.9CDTI injectors....
    Well certain parties have at last admited to changing the nozzles on their injectors after denying said very strongly but I am still on standard Nozzles at 246bhp. It was my impression from Diesel Bob that they had no luck trying to modify my injectors and I was getting a little wound up that they were still holding my funds and a nozzle several weeks later I contacted them today though and it seems they had still been working on them, so clearly a missunderstanding and now believe they have a working uprated nozzle. This is great news for me but not for my bank balance
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Great thanks
    Now your gonna cost me even more money when I start on the engine mods of my cdti
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Good news mate glad ya cracking on so was it bosch that managed to sort them for ya
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    No, Diesel Bob have been working on the injector as a whole, not just nozzles. With the mods they usually do, it did not provide more fuel without losing the atomization due to the pressure drop. When they are happy with them, I will get a full set made up and fitted and see what they can do. At the moment I am maxed out on the injectors with a custom RS map and a custom CRD-T tuning box map to provide as much as I can without the ECU going into limp mode. Without being able to dump the fuel in quicker, I can not get much better results.
    I'm also getting back my 59mm hybrid this weekend after I heavily modified the compressor and had it rebalanced. Hopefully it will spin up alot faster now...
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Hmmmm hopefully you will get it's sorted mate you thought about gettin the ecu out and bdm it I no you wasn't liken the idea but might work to get a bit adjustment
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I'm running 1800bar injector pressure on the remap and an additional 100bar of pressure at some points of the range from the tuning box.
    I have also started to make new pipework myself for the waste gate but I'm not very good at welding XD
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by nutron View Post
    Of the welding
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    what mods have you done to get 246bhp? hybrid turbo and inter cooler but have you done anything else.
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Water:methanol, EGR blank, CAT and silencer removal, K&N panel filter third party MAP sensor and custom map. Alot of money and I have tried alot of other things. The nozzels might make a big difference, worth waiting to see.
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Looks more like I attacked it with the welder than tried to join it
  1. Uprated Clutch....
    By SomeboyMartinJ in forum Diesel Engine related
    Last Post: 17th November 2011, 17:23
  2. Will the v6 cdti injectors fit a 1.9cdti?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2011, 00:56
  3. uprated Turbo for my 1.9CDTi 150
    By yatesy in forum Engine & Drivetrain
    Last Post: 20th February 2011, 23:56
  4. Uprated Rear ARB??
    By Kev_G in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2011, 19:42
  5. uprated dmf
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2009, 11:35
z19dth bigger injectors
vectra c 1.9 uprated fuel injectors
z19dth injector upgrade
bigger injectors cdti 150
best hybrid turbo for 1.9 astra h
z19dth lucas injector
vauxhall 1.9 cdti tuning upgrade
bigger injectors for 19 cdti 150 vector
vauxhall astra sri cdti injectors upgrade
1.9 cdti bigger injectors
vauxhall 1.9 cdti turbo upgrade
z19dtg bigger injectors
upgraded injectors for 1.9 astra sri
astra h 1 9 cdti bigger injectors
fitting insignia injectors into z19dth
z19dth upgrade injectors
z19dth insignia injector upgrade m www.vectra-c.com
remapping injectors vectra c 1.9 cdti
Vectra c 1.9cdti bigger injectors
vectra c 1.9cdti uprated injectors
