Results 1 to 10 of 13
Thread: new HU but no steering control
    Apr 2012
    Kent
    Vehicle : Vectra cdti 1.9
    Trim : Club
    Engine : 1.9 cdti 8v
    Default new HU but no steering control
    I have a 2006 vectra and ive fitted my Alpine 104BT HU today, (i love this unit) i used Autoleads PC99-X81 with patch lead PC99-ALP. followed the instruction and all working except the steering controls.... ive done all i can to make it work, just nothing... i see lots of people have this problem but is there anyone who has fixed it???
    thanks
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Have you plugged in the small jack plug into the rear of the HU?
    I've got an Alpine HU too and all is working well.
    Iirc this is the one I got from this company along with the add on patch lead.
    http://www.dynamicsounds.co.uk/conne...or-p-9113.html
    Feb 2011
    Selby
    Are you sure that PC99-X81 is the correct adapter for your Vectra?
    According to the Autoleads website, PC99-X80 is for Vectra Cs >2005 (and various other Vauxhalls) with steering controls on upper part of steering wheel, whereas PC99-X81 is for Vectra Cs >2005 with the controls on the lower part of the steering wheel.
    Apr 2012
    Kent
    Trim : Club
    yes the jack is pluged in....
    Halfords put my car reg number in and it came up i needed the X81... mines a full canbus, should u have got the X80 then?
    Feb 2011
    Selby
    X80 and X81 are both for full canbus Vauxhalls, but there are two different types of steering wheel controls.
    Apr 2012
    Kent
    Trim : Club
    i have the 3 spoke wheel like this one
    http://www.ebay.co.uk/itm/VAUXHALL-V...item19d0507509
    gwent
    Not being funny but why do people but auto leads patch leads yes then are cheaper than alpine's own but in the end they are not as good buy your self the correct alpine harness and you can control more with it then the auto leads one plus you can get one that you keep the radio station info on the screen
    Apr 2012
    Kent
    Trim : Club
    didnt know i could get one... where from?
    gwent
    If you go to your local car stereo dealer then can get one for you
    South West
    As said, the Autoleads are the cheaper option, but in most cases the correct cable does the job just fine.
    I had an Alpine in my full canbus Vectra before switiching to a CD70. Do your homework if you plan on going with a proper Alpine cable/control unit.
    The cable assy for HU which would give on screen info was £100, and for what it would actually display turned out to be not really worth it IMO. You would only see the name of the audio track, and only if the song info was formatted correctly. It would not show radio station info etc. This was a couple of years ago, so things might have moved on and be able to display things better.
    I ended up using an Autoleads cable which worked just fine and gave me the steering wheel controls.
  1. new stereo**steering control q's**
    By jays_225 in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2011, 20:54
  2. Steering Control ECU
    By ServerKing in forum Engine & Drivetrain
    Last Post: 11th January 2010, 15:49
  3. Steering Control Help!
    By VSRI in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2009, 14:27
  4. steering wheel control
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2008, 22:32
  5. Steering Control Adaptor Help
    By Ben H in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2007, 11:23
