Thread: 1.9 cdti whine coming from the front
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default 1.9 cdti whine coming from the front
    Hello peeps,
    Im not sure if this question has been asked before but a friend of mine as recently aquired a vectra 1.9 cdti now im not sure if its the 120 or the 150.
    He has a problem with a whine coming from the front it sounds like a police siren under acceleration however disappears when going above 30mph it is noticlable to the outside as peoples heads turn has he goes past has anybody had any similar experiences with this kind of problem any help would be great cheers.
    South east
    Turbo? Drive belt tensioner?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    how a look at this post
    http://www.vectra-c.com/forum/showth...=nokiaman+1978
    it may be the alternator
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    have a look at page 12 it says as below
    When my turbo was on its way out it sounded like a police siren,i also had the boost pressure solenoid changed that sits above the radiator on the bonnet slam panel..just behind it and has 2 pipes going to it..advised common
    When alternator on its way got a dry bearing noise on idle and recently on startup had a chirping noise but only first thing in the morning,and only for a couple of minutes..thought it was a idler on its way..turned out water pump on its way and replaced along with timing belt kit.
    Sometimes the noise you hear doesn't fully appear to be what it ends up as
    hope this may help
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Turbo seems the most likely cause based on the symptoms.
  1. 1.9 CDTI Turbo Whine and ECM02345a spanner light + limp mode
    By wakey1512 in forum Engine & Drivetrain
    Last Post: 4th August 2012, 20:18
  2. CDTi 8v Whine
    By welshhuw in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2012, 10:55
  3. whine from front passenger side
    By skip85 in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 22:59
  4. Knocking coming from front of the car!
    By Deano-vec in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2009, 22:03
  5. 1.9 cdti sri whine on start, int lack of power
    By kojak01 in forum Engine & Drivetrain
    Last Post: 21st February 2007, 08:47
1.9 cdti boost solenoid whine
