Results 1 to 10 of 11
Thread: Air con question
    Regular Member Bullylad's Avatar
    Bolton
    Default Air con question
    I have checked the gas level in the system and it is ok, there are no leaks.
    With the engine running I turn the air con on. The revs drop slightly and I can hear something clunk into gear under the bonnet so it all sounds as if it is working as it should do.
    Despite all this it still does not blow out any cold air. It is just like having the normal fan turned on.
    Is there anything else to check or does the gas in the air con need replacing?
    Thanks in advance.
    West
    How did you check it? the gas level may appear ok but if the gas has lost the refrigerant, then it's never going to cool down
    11 Post(s)
    Quote Originally Posted by Bullylad View Post
    Is hte heater stuck on?
    Bolton
    I bought a DIY air con recharge canister and it came with a gauge to check the level. This says that there is already enough gas in the system and it doesnt need topping up.
    Bolton
    I don,t think so, it blows hot and cool air when the air con is not turned off as it should.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    mine does the same
    its been like it for the last 6 years ive had it
    19000 miles when i had its now on 64000 miles
    West
    The trouble with the diy can is ... it doesn't know the difference between gas & refrigerant... all it does is it gives you the pressure, that still doesn't mean you have the correct amount of refrigerant.
    When you go to an air con service centre, the gas is removed completely, this then allows the gas to be tested, then when the vacuum test has finished it is refilled with new gas & the correct amount of refrigerant including a uv dye... which is then all printed on to a sheet for you to see.
    hth
    Dec 2011
    Seaham
    Go to Kwick-Fit, get them to re-charge your system. The machine is automatic, it drains your system and re-cycles any useful gas. It then pressure tests it for leaks and finally re-fills with gas. All for less then £50!
    11 Post(s)
    Never believe what the DIY death kit can tells you.
    It's no replacement for a human being and a machine.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by Ben50n View Post
    as ben50n said i had mine done a few years back for 40 pounds it does not take
    long to do
    i waited about 30 minutes at the garage ice cold now
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
