Thread: Qantas Airlines: Repair Division
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Default Qantas Airlines: Repair Division
    In case you need a laugh:
    Remember, it takes a college degree to fly a plane but only a high school diploma to fix one.
    After every flight, Qantas pilots fill out a form, called a 'Gripe Sheet' which tells mechanics about problems with the aircraft.
    The mechanics correct the problems; document their repairs on the form, and then pilots review the Gripe Sheets before the next flight.
    Never let it be said that ground crews lack a sense of humour.
    Here are some actual maintenance complaints submitted by Qantas' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
    By the way, Qantas is the only major airline that has never, ever, had an accident.
    P: Left inside main tyre almost needs replacement.
    S: Almost replaced left inside main tyre.
    P: Test flight OK, except auto-land very rough.
    S: Auto-land not installed on this aircraft.
    P: Something loose in cockpit.
    S: Something tightened in cockpit.
    P: Dead bugs on windshield.
    S: Live bugs on back-order.
    P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
    S: Cannot reproduce problem on ground.
    P: Evidence of leak on right main landing gear.
    S: Evidence removed.
    P: DME volume unbelievably loud.
    S: DME volume set to more believable level.
    P: Friction locks cause throttle levers to stick.
    S: That's what friction locks are for.
    P: IFF inoperative in OFF mode.
    S: IFF always inoperative in OFF mode.
    P: Suspected crack in windshield.
    S: Suspect you're right.
    P: Number 3 engine missing.
    S: Engine found on right wing after brief search.
    P: Aircraft handles funny............ (I love this one!)
    S: Aircraft warned to straighten up, fly right, and be serious.
    P: Target radar hums.
    S: Reprogrammed target radar with lyrics.
    P: Mouse in cockpit.
    S: Cat installed.
    And the best one for last..................
    P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
    S: Took hammer away from midget.
    Regular Member Islander's Avatar
    Barrow-in-Furness
    quality!
    Full Member
    Mar 2011
    n. ireland
    very funny and so aussie
    Edinburgh
    lol
    And why would Qantas, a civilian airline, have a target radar or an IFF transponder, both military bits of kit...?
    Also not forgetting all the accidents the Qantas HAVE had, too...
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Well they do have IFF, of sorts, and I suppose weather radar might count, but these things are never quite they pretend to be - or new for that matter:
    http://www.freegolfinfo.com/forums/p...aspx?m=1214303
    Quote Originally Posted by vxvirgin View Post
    Oh absolutely - these have doing the rounds for donkeys years...
  1. Walmart airlines
    By bobssignum in forum Comedy & Humour
    Last Post: 1st December 2012, 10:32
  2. Anyone used Delta Airlines?
    By rosssri in forum The 'Off Topic' room
    Last Post: 6th April 2011, 12:23
  3. To repair or not to repair......
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 23:12
  4. zoom airlines
    By billyyoung in forum General Chat
    Last Post: 29th August 2008, 13:29
