Thread: Fault code: 0597 - thermostat urgent help needed please
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Default Fault code: 0597 - thermostat urgent help needed please
    Hi guys.
    My father-in-law's 06' 1.8vvti has just thrown up this fault code 0597 - coolant thermostat valve circuit low voltage.
    Need to get some info ASAP. Anyone know what exactly on the thermostat it will be? Could it be a fuse?
    He had the thermostat and water pump changed in January....
    Any one got any quick advice?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    I would go back to the place that did the work and ask them to sort it out.
    Jan 2012
    Derby
    I agree and they prob will but if it's something like a fuse then I can do it meself :-)
    Jan 2012
    Derby
    Bumpety bump.....anyone?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    take the car out for a drive and then run the engine up to operating temperature, not sure what that is for your but probably about 86c. Pull over and leave the engine running and see what the temp gauge does and whether the fan kicks in about 93c.
    I do think just have a failed thermostat though, not expensive but also delicate bits of kit that are known to fail for no reason.. The garage used probably just fitted a cheapo one and chnaged a lot.
    Jan 2012
    Derby
    Ok, what does it mean if the fan kicks in?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    The VVt has a ECU controlled valve incorporated in the thermostat housing which is why they are more expensive on thus model. It may be loose connection
  1. Thermostat fault ? Advice needed please. Thank you
    By Envy in forum Engine & Drivetrain
    Last Post: 24th October 2012, 17:00
  2. Help needed please, fault code C1532
    By levy9 in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2012, 18:52
  3. fault code..help needed.please
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 12:26
  4. Fault code help needed please help thanks
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 29th March 2011, 18:37
  5. Help needed fault code
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 17th July 2010, 19:42
0597 fault code vectra c
vauxhall vectra fault code 0597
vectra fault xoce 0597
vectra c code0597
vectra c code 0597
vauxhall vectra 2007 fault number 0597
