Thread: Confused over front brake disc size Signum 2.0t
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Confused over front brake disc size Signum 2.0t
    Hi all
    Please help me and my friend out. We are going to have a garage replace his front and rear brake discs and pads.
    The rears are 292mm and we have bought the parts but looking at his fronts they seem to measure around 285mm. I thought these should have been 302mm so its causing us some confusion.
    Could 285mm up front for a 2.0t be right as going by Jezzy's post here it should be 302mm.
    Maybe the previous owner did a swap but note sure.
    Will have the wheel off tomorrow to get an exact measurement, but I just find this a bit strange.
    He has a 2004 2.0t Signum Elegance on 16" Rims.
    Can someone clarify the correct size please.
    Many thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Unless someone has changed them at some point they'll be 302s
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by John IS3 View Post
    Thanks John. Thats what I thought.
    If they are 285mm up front would that casue an issue with the up and coming MOT. Do they take size into account or just the fact they work correctly.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not sure if the MOT takes a front to rear brake imbalance into account, you'd have to look into that one (vosa website)
    Jul 2011
    peterborough
    surely if now got 285 discs then calipers have been changed also or the older calipers & pads for 302mm discs would be hanging over edge of discs ,
    Possibly the old owner wanting to make a quick bit of cash by selling the 302's and fitting some cheap 285's instead...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Anything is possible
    Or they've maybe had a seized caliper and they were the only ones they could lay their hands on
    I wonder if it makes a major difference having bigger brakes on the back than the front like that on a car like the Vectra/Signum...
    South east
    Quote Originally Posted by Envy View Post
    Are you measuring the disk with the wheel still on? That'll never give you an accurate measurement - remember you're looking for a difference of just 17mm between the 285s and 302s.
    My guess would be that the brake balance check in the MOT is for discrepancies between left and right brakes on the same axle, not between front and rear brakes.
    The MOT tester won't have any interest at all in what size the brakes are - you could turn up with a drum conversion on the front brakes - as long as they stop the wheels in an efficient manner, that's fine.
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. signum 2.2 direct brake disc size
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 00:04
  3. Confused about disc size
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 21:16
  4. Brake disc size?
    By joe2187 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2009, 21:22
  5. Brake Disc Size...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 21:22
vectra c 2.0t front disks
front discs vectra 2.0t
elegance T signum brake disc sizes
