Thread: Where is the CTS on 1.8
    Hull
    Default Where is the CTS on 1.8
    Should be getting new CTS delivered any day now, anyone got a photo of where it is on a 03 1.8... can only seem to find details of thermostat on here (which also getting soon)
    Mar 2012
    Kent
    Cts?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Coolant Temperature Sensor. The only one I know of is on the Thermostat housing.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Coolant Temperature Sensor sticking out
    Hull
    Thanks, just had it delivered so will have a hunt for it sticking out of something like that.
    Thinking that I should maybe do this when I get the thermostat and replace both at the same time...
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    http://www.vectra-c.com/forum/showth...erature+sensor
    here you go as well
    thank dasarab for this
    Hull
    So I replaced the cts and thermostat today, and a pain in the ads those pipe fixings are to get off!
    So far so good. Ran it for a good 20 mins after, then about an hour later went about half mile, temp started at just above the lowest mark and quick went up, then stopped steady at around 88-89, heaters also seem a lot toastier. Hoping I now get better mpg...
