Fan control refuses to go above 6 manually (but will go down to zero) on climate control, or increase accordingly automatically, doesn't increase for windscreen demist either.
Any ideas please?
Any ideas please?
No takers?
I can turn the fan by hand and checked all the fuses which are ok.
Come to the conclusion that maybe 7 is as high as the fan goes!
Is there somethig between the dial and the fan that may have failed?
Fan should have 7 forward speeds, 8 if you include OFF...
The fan is controlled by the ECC (speed line) and regulated by the resistor type pack (different to the standard AC type)
