Thread: One for the electrical geniuses
    Default One for the electrical geniuses
    How can I check if something in the car is drawing current from the battery all he time
    Had battery checked at halfords yesterday with a tool they have and it came up noise on the battery , meaning something was drawing current
    Checked everything was off and it still did it
    Unplugged my parrot and it came up fine , although battery was unserviceable
    I just want to know how to check if the parrot is draining the battery all the time
    Any ideas how to do it
    Sent from my iPhone using My thumb
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Nicked off yahoo answers Mark
    Disconnect the battery cable, and connect a test light between the cable and the battery terminal. The light will come on.
    With the doors closed, check for glove box light, trunk light, engine compartment light etc. Make sure the courtesy lights are out. Then begin to remove fuses, one at a time until the light either goes out, or dims considerably. Now you have located the circuit that is the problem. Locate the component or wire or circuit that is the parasitic drain and repair it.
    Feb 2011
    Selby
    If you've got a multimeter, stick it on the current range (you may have to move the leads to different sockets - see the instructions for it if you're not sure how to use it). Then disconnect the battery negative lead. Clip the red probe to the lead and the black probe to the battery negative terminal.
    You should get a reading of under 100mA or so assuming nothing's on (ie just the alarm, door ECU, radio memory etc). Now pull the fuse on the circuit supplying your Parrot. Does the current drop?
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Use a multimeter in line with the positive feed set to current with the ignition on then switch it off and see if it changes.
    Regular Member coldo's Avatar
    Scotland
    What about the alarm system... Does it not draw current when the engine is off etc..?
    Thanks gents will give it a try
    May 2012
    MANCHESTER
    When you are using a mutimeter on amps (A) setting you must use it in line. the vectra c takes about 5 mins to close every thing down when the doors are locked. the reading you want should be below 0.2 amps for a modern vehicle. or if you can get an amp clamp you wont need to disconect the battery. If in dout of the glove box light put your phone on video mode and shut it.
    This will let you know if it goes out.
    I had a drain on a vec c last week and it was the alarm sensors. So removing the fuse for them in the boot fuse box lost the drain.
    Sorry i forgot the fuse number 23 maybe???
    While the amp meter is fitted you can pull fuses one by one while watching the meter to see what circuit the drain is on. Then look further in to that circu it,
    Full Member Big Sig's Avatar
    Remove fuses one at a time? Get a cheap clamp meter, that way you won't need to run a multimeter in series with the load.
    Something like THIS
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Exclamation
    [QUOTE=Big Sig;1808244]Remove fuses one at a time? Get a cheap clamp meter, that way you won't need to run a multimeter in series with the load.
    I thought clamp meters only worked on AC but technology seems to have advanced ?
    If using a multimeter in series (Current setting) don't operate the starter or steering - it may blow your meter because of the high current.
  1. towbar electrical kit
    Last Post: 29th May 2011, 12:13
  2. Electrical help please
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 15:29
  3. electrical
    By leerawlings in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2010, 22:14
  4. electrical
    By lee324uk in forum Engine & Drivetrain
    Last Post: 1st December 2008, 09:34
  5. FAO computer tech geniuses, lol...
    By Green Growler in forum General Chat
    Last Post: 23rd July 2008, 22:01
