Hi Folks,
Just an FYI on a problem I had with my ZC Vectra CD player. The CD player refused to play CD's or eject (radio still worked fine). When trying to eject, the display showed a "CD Error" message.
To reset the unit, I pulled the radio fuse (number one in the fuse box at the end of the dash) for several seconds. On replacing the fuse, the CD player powered up fine (did not even need to reset the security codes) and resumed normal functions. I pulled the fused because it was much easier than disconnecting the battery.
Hope this might help someone....
