Thread: Starting problem
    Regular Member sberrow's Avatar
    Newport (Gwent)
    Default Starting problem
    I have a problem when starting the car from cold. It struggles to start, when I does it runs very rough untill you press the throttle. When you do you get a lot of white/black/blue smoke. Once you get to 3.5k revs it clears and runs normal. Runs fine after this and starts fine if warm????? Any help
    Newport (Gwent)
    This is for my 55 plate cdti 120 Sri
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    http://www.vectra-c.com/forum/showthread.php?t=156342
    this is a good thread to read.
    First thing u can do is unplug the coolant temp sensor on ur header tank and try to start it. This sensor controls the glow plug relay which times the heating.
    Its the plug on the coolant header tank.
    Newport (Gwent)
    Cheers, now sorted thanks
    Feb 2012
    Ipswich
    What was the problem?
    EDIT: just so when a another member searchs bad starting itll help them.
    Newport (Gwent)
    Unplugged the temp sensor and starts fine
    Feb 2012
    Ipswich
    Good stuff.
  1. starting problem
    By tiimi in forum Troubleshooting
    Last Post: 25th October 2012, 20:32
  2. Starting problem
    By trace in forum Insignia Chat (READ ONLY)
    Last Post: 7th April 2010, 07:18
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
